    Issues with z homing?
    z axis home
    • annikamarsundefined
      annikamars
      Hello! I've mounted a tall extruder on my X-carriage, and as a result my Z-range is very limited (less than 30mm, this is fine for my purposes). I'm running into a problem with using G30 in my z-homing procedure though—the Z-axis just keeps going up after it turns around when the Z-probe triggers, and crashes into the frame. I've tried limiting the Z-axis from 0-10mm just to see if this will stop the motion, but it still goes up until it hits the frame. I've also tried sending the Z-axis to Z=5 or another small value right after running G30, but again no luck. Does anyone have any ideas on why this could be happening? Is significant upwards travel a part of the G30 command, and is there any way around this? Any insights are appreciated!
      • fcwiltundefined
        fcwilt @annikamars
        @annikamars
        Please post your config.g file.
        There are settings for a Z probe which can affect Z travel during probing.
