NPN Proximity sensor on Duet 6HC
I would like to replace the EdingCNC Controller on my CNC-Router with a Duet 6HC.
The machine is equipped with NPN Proximity endstop sensors (OMRON E28B-S08LS01-MC-C2)
The Mainboard is powered from a 48V power supply and the sensors are powered from a seperate 24V power supply.I have connected the signal wire (black) to the io0.in pin, (brown) to +24V an (blue) to -24V.
Now in standstill, can confirm that the endstop is triggering correctly when a metal object is placed in front of the sensor by sending M119.But when I try to home one axis, the matching end stops triggers as soon as the motor moves. Even when I wire the end stop directly in the cabinet with a good distance to the motor wires, the issue persists.
I do not understand how the same configuration works with the old controller but not with the duet.I am on RRF 3.5-rc.1
; Configuration file for Duet 3 MB 6HC (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.16 on Thu Oct 19 2023 17:22:28 GMT+0200 (Mitteleuropäische Sommerzeit) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"CNC" ; set printer name ; Network M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Device Mode M453 ; Set device mode to CNC ; Drives M569 P0.0 S0 ; physical drive 0.0 goes forwards M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P0.3 S1 ; physical drive 0.3 goes forwards M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X320 Y320 Z160 E420.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X2000 Y4200 Z4200 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X1010 Y1245 Z200 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in M574 Y2 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io1.in M574 Z1 S1 P"io3.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io3.in ; Z-Probe M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X15:215 Y15:195 S20 ; define mesh grid ; Sensors M308 S4 Y"drivers" A"DRIVERS" ; configure driver temperature sensor ; Heaters ; Fans ; Tools M563 P0 D0 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined
@dc42 Thank you for your feedback.
Inverting the input was the first thing I tried without success.
In this case I did not design or build the control cabinet, I can only recon that the 48V and 24V PSU do not share a common ground and therefore the end stops behave strange.
When powering the duet and endstops from the same 24V PSU everything works as intended.
@MaxGyver if it's a normally open NPN sensor then you need to tell RRF to invert the input so that a low voltage indicates that the endstop is triggered. Do this by using
"!io0.in"
instead of"io0.in"
in the M574 command. -
undefined MaxGyver has marked this topic as solved
