Global Variables Desire
Firmware wishlist
355
  • undefined
    fcwilt
    It would save me a good deal of time and a bit of frustration, when creating a new set of configuration files, if there was a way to erase all global variables as part of doing a board reset or code re-start.
    Unless there is a way I have not heard about, right now I have to reset the main board which then means I have to re-home the printer and do whatever else needed to restore the state of the printer.
    It's not a big issue to be sure but I would like to have it just the same.
    Thanks.
    undefined 1 Reply Last reply 21 Oct 2023, 00:00 Reply Quote 0
    • undefined
      moth4017 @fcwilt
      @fcwilt
      i manually swap tool heads so have to make a few changes , i use macros to redefine all the changes , i used the cnc kitchen method,
      https://www.cnckitchen.com/blog/tool-swapping-with-the-whambam-mutant-v2-review
      undefined 1 Reply Last reply 21 Oct 2023, 00:38 Reply Quote 0
      • undefined
        fcwilt @moth4017
        @moth4017
        Interesting system - I am going to check it out.
        As to global variables:
        I have one file called create_globals.g.
        It contains some 80 values, most of what is unique to any given printer.
        What that means is I can reuse many commonly needed files not by editing the a multiplicity of files but by editing the values in create_globals.g.
        During development of a new configuration these values may change frequently and the file needs to be executed again which currently I can only do by resetting the board.
        Yes I could include code like some folks which uses exist and either creates or sets the variable. Not elegant.
        So a command to delete all existing global variables would be a boon for me. Not a necessity but just something nice to have.
        Thanks for the feedback - I'm looking forward to giving the mutant system a trial.
        undefined 1 Reply Last reply 21 Oct 2023, 00:50 Reply Quote 0
        • undefined
          moth4017 @fcwilt
          @fcwilt i didnt intend to promote the mutant system 🙂 just the way Stephan used the macros to change the settings ..
          undefined 1 Reply Last reply 21 Oct 2023, 01:19 Reply Quote 0
          • undefined
            fcwilt @moth4017
            @moth4017 said in Global Variables Desire:
            Oh...
            No matter - the system looked interesting.
            I was just thinking about such a system a couple of days back as I was replacing the tools in my E3D Tool Changer dealing with all new cabling.
            As to the guys system - I didn't understand why he was creating a new file rather than selecting from a set of existing ones. But many ways to skin cat.
            Thanks.
            undefined 1 Reply Last reply 21 Oct 2023, 01:47 Reply Quote 0
            • undefined
              moth4017 @fcwilt
              @fcwilt i have different tool heads on my printer so i need to reconfigure the printer , it takes me about 2 minutes to swap the head, and then i run a macro for that tool head that loads all the parameter's in to tool.g file so i only have to run the macro when i change the tool head ,
              undefined 1 Reply Last reply 21 Oct 2023, 02:12 Reply Quote 0
              • undefined
                fcwilt @moth4017
                Understood.
                Does the code that gets written to tool.g for any given tool head change frequently?
                I was thinking settings for any given tool head didn't change often and you only need to select from a set of settings, the settings for the specific tool head being mounted.
                Yes? No?
                Thanks.
                undefined 1 Reply Last reply 21 Oct 2023, 02:33 Reply Quote 0
                • undefined
                  moth4017 @fcwilt
                  @fcwilt
                  im not sure i understand your question, but the settings have to change when i change the tool head eg. steps/mm, z offset , max temperature, pressure
                  advance etc etc
                  undefined 1 Reply Last reply 21 Oct 2023, 12:20 Reply Quote 0
                  • undefined
                    fcwilt @moth4017
                    @fcwilt
                    advance etc etc
                    I understand that but generating a new tool.g file when changing a tool head is just one way to deal with the issue.
                    You could have a single file that uses conditional code to access different sections of code, one section for each tool head. Then all you need is a global variable with a suitable value to indicate which tool head is mounted. That value then determines which section of code needs to be executed.
                    Not a big deal out all, just thinking out loud.
                    undefined 1 Reply Last reply 21 Oct 2023, 21:21 Reply Quote 0
                    • undefined
                      moth4017 @fcwilt
                      @fcwilt originally i was going to put an address on each tool head so that the printer would auto configure , but i didnt have enough inputs free on my control board , so ended up doing the macro route , its still something im going to look at using an analogue input 0v=tool 1, 1v = tool 2 etc this way i only use 1 input .
                      then you could did the setup via global variable's or macros , i like the macro route as all the settings for the too head are in one place .
                      10 out of 10
