3.5.0 rc1 and beta 4 - 12864 L parameter does not work
I'm trying to add filament load and unload scripts to my menu files.
Adding a script to a button with an L parameter does not work. The button just does not do anything when pressed.
Doing it with the filaments menu is also not possible since the command M721 S"PLA" contains quotes and thus cannot be put inside the A"gcode" command.
@dc42 yes I think this is the issue.
I thought I also encountered it on beta 4 but it is possible the firmware didn't flash back to the previous version correctly.
