    Strange numerics
    Gcode meta commands
    • wschadowundefined
      wschadow
      I stumbled across this issue
      var dnozzle1 = heat.heaters[1].model.deadTime
      var dnozzle2 = (10.0* heat.heaters[1].model.deadTime) / 10.0
      echo {var.dnozzle1}^"  "^{var.dnozzle2}
      Rounding is done in a mysterious way.
      • o_lampeundefined
        o_lampe @wschadow
        @wschadow Do you know for sure, that the true value is 5.7 ? It might just be truncated in a different way when echo prints OM-values directly?
        wschadowundefined 1 Reply Last reply Reply Quote 0
        • wschadowundefined
          wschadow @o_lampe
          @o_lampe here is another example:
          var enozzle1 = heat.heaters[1].model.coolingExp
          var enozzle2 = (10.0 * heat.heaters[1].model.coolingExp) / 10.0
          echo {var.enozzle1}^"  "^{var.enozzle2}
          According to the documentation the default value is 1.35. There is something wrong with the assignment / rounding of variables.
          • wschadowundefined
            wschadow @wschadow
            To me this looks like a bug in the assignment / conversion / rounding:
            var enozzle1 = 1.0*heat.heaters[1].model.coolingExp
            var enozzle2 = 1.00000001*heat.heaters[1].model.coolingExp
            var enozzle3 = (10.0 * heat.heaters[1].model.coolingExp) / 10.0
            echo {var.enozzle1}^"  "^{var.enozzle2}^"  "^{var.enozzle3}
              dc42 administrators @wschadow
              @wschadow each object model value has a default number of decimal places, which is the number of decimal places that is provided when you enquire of that value. This is done because if we represented all floating point values to the full 7 decimal places, the volume of text returned by the object model to DWC, PanelDue and other user interfaces would be a lot larger for no gain. Also it would look silly if user messages gave e.g a selected temperature as 205.5000 rather than 205.5.
              If you perform maths on object model values then the result is always provided to 7 decimal places.
              wschadowundefined 2 Replies Last reply Reply Quote 0
              • wschadowundefined
                wschadow @dc42
                @dc42 ok, thanks for the explanation. Of course it makes to display only the significant digits or a certain number of digits. The problem here is that too few digits are displayed. When I write these variable to a file I get wrong numbers (1.4 will be written). When reading them and assigning them to variables in the object model, they are set to the wrong values.
                • wschadowundefined
                  wschadow @dc42
                  @dc42 This brings me also to another request: https://github.com/Duet3D/PanelDueFirmware/issues/317
                  The object model seems to change the number of digits for x and y depending on the number it cuts off trailing zeros, which is fine. DWC and Paneldue show for x and y only one digit after the ".". It would be very helpful, e.g. the x y offset calibration of an ODEX machine, to display to digits. There is enough room for that.
                  wschadow created this issue in Duet3D/PanelDueFirmware
                  closed Two digits for the display of x and y coordinates #317
