    DSF & DWC Downgrade from 3.5.0rc1 to 3.4.6-2 doesnt work
    Firmware installation
    • DavidG_68kg_PLAundefined
      DavidG_68kg_PLA
      Hey Guys,
      6HC with SBC:
      At first the update to beta4 went fine. All boards, DSF and DWC updated automatically.
      Then I went to rc1 because I experienced some issues, but the DWC didnt upgrade to rc1 and stayed at beta4.
      With all boards on rc1 except the DWC on beta4 i had machine freezes mid print.
      Now my downgrade to the last stable package freezed in line:
      Setting up reprapfirmware (3.4.6-2) ...
      login as: pi
      pi@192.168.85.140's password:
      Linux T3000SE-L67W2 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Wed Oct 18 13:03:45 2023 from 10.3.141.73
      pi@T3000SE-L67W2:~ $ sudo rm -f /etc/apt/sources.list.d/duet3d-unstable.list
      [1]+  Exit 1                  nohup /usr/bin/onboard > /dev/null 2>&1
      pi@T3000SE-L67W2:~ $ sudo bash -c "echo 'deb https://pkg.duet3d.com/ stable armv7' > /etc/apt/sources.list.d/duet3d.list"
      pi@T3000SE-L67W2:~ $ sudo apt update
      Get:1 https://linux.teamviewer.com/deb stable InRelease [11.9 kB]
      Get:2 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
      Get:3 https://deb.nodesource.com/node_16.x buster InRelease [4,584 B]
      Get:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [400 kB]
      Get:5 https://pkg.duet3d.com stable InRelease [2,563 B]
      Get:6 https://pkg.duet3d.com stable/armv7 armhf Packages [29.3 kB]
      Get:7 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
      Get:8 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
      Fetched 13.5 MB in 14s (952 kB/s)
      Reading package lists... Done
      Building dependency tree
      Reading state information... Done
      All packages are up to date.
      pi@T3000SE-L67W2:~ $ sudo apt dist-upgrade
      Calculating upgrade... Done
      The following packages were automatically installed and are no longer required:
        libauthen-sasl-perl libdata-dump-perl libencode-locale-perl libfile-listing-perl libfont-afm-perl libglade2-0
        libhiredis0.14 libhtml-form-perl libhtml-format-perl libhtml-parser-perl libhtml-tagset-perl libhtml-tree-perl
        libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl libhttp-message-perl libhttp-negotiate-perl
        libio-html-perl libio-socket-ssl-perl libjpeg-turbo-progs liblwp-mediatypes-perl liblwp-protocol-https-perl
        libmailtools-perl libmemcached11 libmemcachedutil2 libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl
        libpeas-1.0-0 libpeas-common libtimedate-perl libtry-tiny-perl libturbojpeg0 liburi-perl libwww-perl
        libwww-robotrules-perl perl-openssl-defaults proftpd-doc xscreensaver-data
      Use 'sudo apt autoremove' to remove them.
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
      Hit:3 https://linux.teamviewer.com/deb stable InRelease
      Hit:4 https://pkg.duet3d.com stable InRelease
      Get:5 https://deb.nodesource.com/node_16.x buster InRelease [4,584 B]
      Fetched 4,584 B in 4s (1,203 B/s)
      pi@T3000SE-L67W2:~ $ rm -f ./reprapfirmware*.deb
      pi@T3000SE-L67W2:~ $ apt download reprapfirmware/stable
      Get:1 https://pkg.duet3d.com stable/armv7 armhf reprapfirmware all 3.4.6-2 [1,249 kB]
      Fetched 1,249 kB in 3s (418 kB/s)
      pi@T3000SE-L67W2:~ $ sudo dpkg -i --force-depends ./reprapfirmware*.deb
      dpkg: warning: downgrading reprapfirmware from 3.5.0~rc.1-1 to 3.4.6-2
      (Reading database ... 109532 files and directories currently installed.)
      Preparing to unpack .../reprapfirmware_3.4.6-2_all.deb ...
      Unpacking reprapfirmware (3.4.6-2) over (3.5.0~rc.1-1) ...
      ^Cdpkg: error processing package reprapfirmware (--install):
       installed reprapfirmware package post-installation script subprocess was interrupted
      Errors were encountered while processing:
       reprapfirmware
      (Reading database ... 109528 files and directories currently installed.)
      Unpacking reprapfirmware (3.4.6-2) over (3.4.6-2) ...
      Restarted the machine and the process:
      login as: pi
      Last login: Mon Oct 23 07:55:04 2023 from 10.3.141.73
      Get:2 https://deb.nodesource.com/node_16.x buster InRelease [4,584 B]
      Get:3 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
      Hit:4 https://linux.teamviewer.com/deb stable InRelease
      Hit:5 https://pkg.duet3d.com stable InRelease
      Get:6 http://archive.raspberrypi.org/debian buster/main armhf Packages [400 kB]
      Fetched 437 kB in 4s (104 kB/s)
      E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
      pi@T3000SE-L67W2:~ $ ^C
      pi@T3000SE-L67W2:~ $ sudo dpkg --configure -a
      There is 1 outdated board:
      - Duet 3 Expansion EXP1HCL (3.5.0-rc.1 -> 3.4.6) @ CAN address 123
      Would you like to update them all (Y/n)? y
      Updating firmware on board #123... Done!
      Resetting mainboard... Done!
      but the DWC was still on 3.5.0-beta.4 and the DSF on 3.5.0-rc.1. Now after a M997 and some restarts both is frankly on rc.1:
        DavidG_68kg_PLA
        Tried to update to rc1 again, but it stated
        E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
        You might want to run 'apt --fix-broken install' to correct these.
        The following packages have unmet dependencies:
         duetsoftwareframework : Depends: reprapfirmware (>= 3.5.0~rc.1-1) but 3.4.6-2 is installed
        pi@T3000SE-L67W2:~ $ apt --fix-broken install
        E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
        E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
        pi@T3000SE-L67W2:~ $ y
        -bash: y: command not found
        pi@T3000SE-L67W2:~ $ sudo killall apt apt-get
        apt: no process found
        apt-get: no process found
        pi@T3000SE-L67W2:~ $ sudo rm /var/lib/apt/lists/lock
        pi@T3000SE-L67W2:~ $ sudo rm /var/cache/apt/archives/lock
        pi@T3000SE-L67W2:~ $ sudo rm /var/lib/dpkg/lock*
        Get:4 https://deb.nodesource.com/node_16.x buster InRelease [4,584 B]
        Hit:5 https://pkg.duet3d.com unstable InRelease
        Fetched 4,584 B in 4s (1,287 B/s)
        1 package can be upgraded. Run 'apt list --upgradable' to see it.
        • chrishammundefined
          chrishamm administrators @DavidG_68kg_PLA
          @DavidG_68kg_PLA Please follow the full instructions at https://docs.duet3d.com/en/User_manual/Machine_configuration/DSF_RPi#downgrade-packages, in particular step 6.
          Duet software engineer
          DavidG_68kg_PLAundefined 1 Reply Last reply Reply Quote 0
            DavidG_68kg_PLA @chrishamm
            @chrishamm thanks! That helped for the DSF.
            But the DWC is still on rc1.
            Here's my log:
            login as: pi
            Last login: Mon Oct 23 10:59:29 2023 from 10.3.141.73
            Fetched 36.4 kB in 4s (9,758 B/s)
            Fetched 1,249 kB in 5s (229 kB/s)
            All boards are up-to-date!
            pi@T3000SE-L67W2:~ $ sudo apt install -y --allow-downgrades duetsoftwareframework/stable duetcontrolserver/stable duetwebserver/stable duetpluginservice/stable duettools/stable duetruntime/stable duetwebcontrol/stable duetpimanagementplugin/stable
            Selected version '3.4.6' (stable [armhf]) for 'duetsoftwareframework'
            Selected version '3.4.6' (stable [armhf]) for 'duetcontrolserver'
            Selected version '3.4.6' (stable [armhf]) for 'duetwebserver'
            Selected version '3.4.6' (stable [armhf]) for 'duetpluginservice'
            Selected version '3.4.6' (stable [armhf]) for 'duettools'
            Selected version '3.4.6' (stable [armhf]) for 'duetruntime'
            Selected version '3.4.6' (stable [all]) for 'duetwebcontrol'
            Selected version '3.4.6' (stable [armhf]) for 'duetpimanagementplugin'
            Recommended packages:
              proftpd duetpluginservice
            The following packages will be DOWNGRADED:
              duetcontrolserver duetpimanagementplugin duetpluginservice duetruntime duetsoftwareframework duettools
              duetwebcontrol duetwebserver
            0 upgraded, 0 newly installed, 8 downgraded, 0 to remove and 0 not upgraded.
            Need to get 44.3 MB of archives.
            After this operation, 0 B of additional disk space will be used.
            Get:1 https://pkg.duet3d.com stable/armv7 armhf duetpimanagementplugin armhf 3.4.6 [4,912 kB]
            Get:2 https://pkg.duet3d.com stable/armv7 armhf duetpluginservice armhf 3.4.6 [66.6 kB]
            Get:3 https://pkg.duet3d.com stable/armv7 armhf duetsoftwareframework armhf 3.4.6 [2,106 B]
            Get:4 https://pkg.duet3d.com stable/armv7 armhf duetwebserver armhf 3.4.6 [86.4 kB]
            Get:5 https://pkg.duet3d.com stable/armv7 armhf duettools armhf 3.4.6 [56.7 kB]
            Get:6 https://pkg.duet3d.com stable/armv7 armhf duetcontrolserver armhf 3.4.6 [249 kB]
            Get:7 https://pkg.duet3d.com stable/armv7 armhf duetruntime armhf 3.4.6 [28.4 MB]
            Get:8 https://pkg.duet3d.com stable/armv7 armhf duetwebcontrol all 3.4.6 [10.5 MB]
            Fetched 44.3 MB in 9s (5,178 kB/s)
            dpkg: warning: downgrading duetpimanagementplugin from 3.5.0~rc.1 to 3.4.6
            Preparing to unpack .../0-duetpimanagementplugin_3.4.6_armhf.deb ...
            Unpacking duetpimanagementplugin (3.4.6) over (3.5.0~rc.1) ...
            dpkg: warning: downgrading duetpluginservice from 3.5.0~rc.1 to 3.4.6
            Preparing to unpack .../1-duetpluginservice_3.4.6_armhf.deb ...
            Unpacking duetpluginservice (3.4.6) over (3.5.0~rc.1) ...
            dpkg: warning: downgrading duetsoftwareframework from 3.5.0~rc.1 to 3.4.6
            Preparing to unpack .../2-duetsoftwareframework_3.4.6_armhf.deb ...
            Unpacking duetsoftwareframework (3.4.6) over (3.5.0~rc.1) ...
            dpkg: warning: downgrading duetwebserver from 3.5.0~rc.1 to 3.4.6
            Preparing to unpack .../3-duetwebserver_3.4.6_armhf.deb ...
            Unpacking duetwebserver (3.4.6) over (3.5.0~rc.1) ...
            dpkg: warning: downgrading duettools from 3.5.0~rc.1 to 3.4.6
            Preparing to unpack .../4-duettools_3.4.6_armhf.deb ...
            Unpacking duettools (3.4.6) over (3.5.0~rc.1) ...
            dpkg: warning: downgrading duetcontrolserver from 3.5.0~rc.1 to 3.4.6
            Preparing to unpack .../5-duetcontrolserver_3.4.6_armhf.deb ...
            Unpacking duetcontrolserver (3.4.6) over (3.5.0~rc.1) ...
            dpkg: warning: downgrading duetruntime from 3.5.0~rc.1 to 3.4.6
            Preparing to unpack .../6-duetruntime_3.4.6_armhf.deb ...
            Unpacking duetruntime (3.4.6) over (3.5.0~rc.1) ...
            dpkg: warning: downgrading duetwebcontrol from 3.5.0~rc.1 to 3.4.6
            Preparing to unpack .../7-duetwebcontrol_3.4.6_all.deb ...
            Unpacking duetwebcontrol (3.4.6) over (3.5.0~rc.1) ...
            Setting up duetruntime (3.4.6) ...
            Setting up duetwebcontrol (3.4.6) ...
            Setting up duetcontrolserver (3.4.6) ...
            Installing new version of config file /opt/dsf/conf/config.json ...
            Setting up duettools (3.4.6) ...
            Setting up duetwebserver (3.4.6) ...
            Setting up duetsoftwareframework (3.4.6) ...
            Setting up duetpluginservice (3.4.6) ...
            Installing new version of config file /opt/dsf/conf/plugins.json ...
            Setting up duetpimanagementplugin (3.4.6) ...
              Phaedrux Moderator @DavidG_68kg_PLA
              @DavidG_68kg_PLA said in DSF & DWC Downgrade from 3.5.0rc1 to 3.4.6-2 doesnt work:
              Try clearing your browser cache.
                DavidG_68kg_PLA @Phaedrux
                @Phaedrux thanks! That helped a lot 😉
