E3d Toolchanger Duet2 Raspberry Pi4
Ok I have a huge favor to ask. I just purchased a E3d Toolchanger which is wired to a Duet 2 and expansion board. It also comes with a touchscreen so it has the panel board. I was also given a Raspberry PI4 with it and it has a usb cable plugged into the Duet coming out of the back. Is it possible this printer with this board could have run a raspberry Pi4 and if so how do I go about figuring out why or what is on it.
@amcdave I don't think the duet 2 can run in SBC mode, you can however use the PI4 to access DWC, slice the files and upload the Gcode via the USB but you will need a monitor, keyboard and or mouse, or use something like VNC to remote connect to the PI4.
Link to all the docs -
https://docs.duet3d.com/ -
@amcdave the RPi might have been used to control the Duet with Octoprint or Repetier Host. You don’t really need it if you connect the Duet to your network.
