    retrieve the WiFi connection data and save it to the SD card
    Firmware installation
    • axiomundefined
      axiom
      I have to replace my board because of a defect. Is there a way to retrieve the WiFi connection data and save it to the SD card so that I simply have to put the existing SD card in the new board and continue straight away?
      droftartsundefined A Former User? 2 Replies Last reply Reply Quote 0
        droftarts administrators @axiom
        @axiom Unfortunately not. You can do a scan (if you have the latest beta firmware), but the actual negotiation and connection are done by the WiFi module.
        • A Former User?
          A Former User @axiom
          @axiom look at Phaedrux post https://forum.duet3d.com/topic/15030/can-t-access-wifi/32
          You can create a file with the SSID and password in it and run that to provision the new board.
