    Autocalibration - Heat map always below bed
    • totalitarian
      totalitarian last edited by
      Can anyone explain why my heatmap always shows below the bed?
      I have a BLTouch that is used to set the Z height and mesh.
      Here are my configs
      config.g
      ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
      ; generated by RepRapFirmware Configuration Tool on Sun Dec 10 2017 14:24:02 GMT+0000 (GMT Standard Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M667 S1 ; Select CoreXY mode
      M208 X300 Y275 Z300 S0 ; Set axis maxima
      M574 X1 Y2 Z1 S0 ; Set active high endstops
      M92 X80 Y80 Z1120 E400 ; Set steps per mm
      M350 X16 Y16 I0 ; Configure microstepping with interpolation
      M350 Z16 E16 I0 ; Configure microstepping with interpolation
      M566 X1000 Y1000 Z200 E400 ; Set maximum instantaneous speed changes (mm/min)
      M203 X12000 Y12000 Z2400 E24000 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z10 E400 ; Set max accelerations (mm/s^2)
      M204 P1200.000 T1600.000 R800.000 ; more acceleration
      M906 X1050 Y1050 Z1050 E840 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
      M563 P0 D0 H1 F2; Define tool 0
      M550 PGecko ; Set machine name
      M552 S1 ; Enable network
      M587 S"f1xter-ext" P"v1deoworld" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S1 ; Enable FTP
      M586 P2 S1 ; Enable Telnet
      M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      T0 ; Select first tool
      ;BLTouch
      M307 H3 A-1 C-1 D-1 ;
      M558 P5 X0 Y0 Z1 H5 F320 T6000; F probe speed - T Travel speed
      G31 X30 Y5 Z0.6 P25
      ;INCREASE VALUE WILL LOWER NOZZLE CLOSER TO THE BED, DECREASE THIS VALUE WILL RAISE THE NOZZLE FROM THE BED
      M557 X40:260 Y40:260 S55   ; probe from X=20 to 280, Y=20 to 280mm with a mesh spacing of 65mm
      M501
      Home all.g
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool on Sun Oct 29 2017 11:44:20 GMT-0700 (MST)
      ; Relative positioning
      G91
      ; Lift Z
      G1 Z5 F6000
      ; Course home X or Y
      G1 X-305 Y305 F1800 S1
      ; Course home X
      G1 X-305 S1
      ; Course home Y
      G1 Y305 S1
      ; Move away from the endstops
      G1 X5 Y-5 F6000
      ; Fine home X
      G1 X-305 F360 S1
      ; Fine home Y
      G1 Y305 S1
      G91                ; relative mode
      G1 Z5 F320         ; raise head 5mm to ensure it is above the Z probe trigger height
      G90                ; back to absolute mode
      G1 X150 Y150 F2000 ; put head over the centre of the bed, or wherever you want to probe
      M401; deploy probe
      G30                ; lower head, stop when probe triggered and set Z to trigger height
      M402; retract probe
      ; Absolute positioning
      G90
      ; Tell the firmware where we are
      ;G92 Z0
      ; Uncomment the following line to lift the nozzle after probing
      G1 Z5 F320
      Override
      ; Heater model parameters
      M307 H0 A15.6 C85.1 D5.7 S0.40 B0
      M307 H1 A225.0 C98.5 D6.1 S0.80 B0
      M307 H2 A340.0 C140.0 D5.5 S1.00 B0
        It usually means that the Z=0 position that is set by Z homing isn't accurate. But you are homing with the bltouch too. Are you sure that you don't have another G31 command somewhere that is setting a different Z probe trigger height?
        • totalitarian
          Should I be setting
          [c]G92 Z0[/c]
          in my home.g and homeall.g?
            @totalitarian:
            Should I be setting
            [c]G92 Z0[/c]
            Only if you are homing Z using a Z min endstop switch that triggers at exactly Z=0.
            After homing Z, if you command the head to Z=0, is the nozzle just touching the bed?
            Are you sure that mesh probing is succeeding? If it is failing for any reason, DWC could be displaying an old height map file.
