Request for Change to Apparmor setting
I'm developing a lightweight plugin to stream raspberry pi cameras via a url (piStream)
Apparmor blocks a vital part of the proceedings (3.5.0-rc.1). One of the underlying libraries needs access to /dev/media*.
There does not seem to be an sbcPermissions setting to accomodate this.As a workaround I manually edited /etc/apparmor.d/dsf.piStream to include
/dev/media* rwmlk,
Can the setting for
webcamAccess
be modified to include /dev/media (seems appropriate)? Or some other solution?Thanks in advance.
<snip> network, /dev/video* rwmlk, /dev/media* rwmlk, /usr/bin/libcamerify rm, <snip>
My current sbcPermissions are:
"sbcPermissions": ["commandExecution", "objectModelReadWrite", "objectModelRead","networkAccess", "webcamAccess", "readSystem", "writeSystem", "fileSystemAccess","launchProcesses", "managePlugins"],
@stuartofmt What does /dev/media* expose?
@chrishamm said in Request for Change to Apparmor setting:
Its one of the usual places (along with /dev/video) where camera device nodes are created. Specifically the new (Bullseye) pi camera libraries use it for the pi native cameras. Of course other "media" devices may get a node in /dev/media (camera-microphone combos, microphones, tv tuners etc.)
I think the subtle distinction (by convention ?) is that a devices with a node in /dev/media can be interrogated via various API's e.g. V4L2 and ALSA.
Here is the full dsf.piStream I am using. I did not add anything other than the one line
/dev/media* rwmlk
. As you can see the libcameraxx are already included. I'm actually using the picamera2 python module (but that calls the libcameraxx api's)pi@srsender:~ $ cat /etc/apparmor.d/dsf.piStream # Last Modified: Thu Feb 17 11:26:25 2022 #include <tunables/global> /opt/dsf/plugins/piStream/** { #include <abstractions/base> #include <abstractions/bash> #include <abstractions/python> #include <abstractions/user-tmp> #include <abstractions/nameservice> /usr/bin/python{2.[4-7],3.[0-9]} ix, /usr/local/lib{,32,64}/python{2.[4-7],3,3.[0-9]}/{site,dist}-packages/** r, /opt/vc/lib/** rm, capability dac_override, capability dac_read_search, capability sys_nice, /opt/dsf/bin/* rm, owner /opt/dsf/plugins/piStream/ r, owner /opt/dsf/plugins/piStream/** rwmlk, owner /proc/** rw, /sys/** r, /{,var/}run/dsf/** rw, /opt/dsf/plugins/ r, /opt/dsf/plugins/** rw, /opt/dsf/sd/sys/ r, /opt/dsf/sd/sys/** r, /opt/dsf/sd/sys/** wk, / rw, /** rw, /** mix, network, /dev/video* rwmlk, /dev/media* rwmlk, /usr/bin/libcamerify rm, /usr/share/libcamera/** r, /usr/libexec/libcamera/* rm, }
@stuartofmt Okay thanks for the info. I will add this particular rule to v3.5.
