    Talos IDEX Large Format 3D Printers by Project R3D
    My Duet controlled machine
    1
    1
    318
    • projectR3Dundefined
      projectR3D
      Project R3D has recently released our new line of Talos printers. The Talos is designed to be a feature-packed large-format printer aimed to be a workhorse for many industries. With build volumes ranging from 600x600x600mm up to 600x1800x600mm you can print full automotive body panels all at once.
      Find out more at https://www.projectr3d.com/
      IDEX is standard on all Talos units, allowing for several different print configurations. Support removal and post-processing of the part can be a major hassle when working with such large parts, having a dedicated support material allows for effortless removal and minimal cleanup. Speed is always a factor in additive, but with such large build volumes, speed is even more critical. Running a high-detail nozzle for small details or walls and then having a large nozzle for supports and infill can drastically reduce print time.
      When it comes to speed, the Talos has it. Rapids in X,U, and Y are limited to 1000mm/sec. The only thing holding you back will be your hotends volumetric flow rate.
      We offer the Talos assembled or as sub-assemblies for those who can't fit an assembled unit into their shop.
      1800 Top Right.png 1200 Enclosed Front.png 1200  Front Right.png 600 Front.png 600 Enclosed Top Right.png
      We offer the Hemera Revo, Bondtech LGX/Mosquito Magnum, and Bondtech LGX/Mosquito Magnum+.
      When we set out to design the Talos, we wanted to accomplish a couple of things, we are glad to say we did!
      • Duet3 ecosystem of electronics to allow for expansion and upgrades ✔
      • Fastest printers in the category ✔
      • Feature packed, make competitors options standard in the Talos (IDEX, Linear Rails, Casters) ✔
      • Best price in the category ✔
      • Robust build quality✔
      • Assembled✔
      • Sub-assembly kit allowing for 2 hour assembly time, rather than 4-7 days with competition✔
      • Highest Quality Components✔
      • Camera assisted calibration✔
