    60V capable 6HC/3HC/1HCL
    Hardware wishlist
    • Anon1337undefined
      Anon1337
      Again. Title says it all.
      • fcwiltundefined
        fcwilt @Anon1337
        @Anon1337
        What elements require 60 volts?
        Given the likely small market for such products it might make sense to simply "boost" the outputs of the existing products.
        Anon1337undefined 1 Reply Last reply Reply Quote 0
        • Anon1337undefined
          Anon1337 @fcwilt
          @fcwilt the motors run better at 60V when you push it
          Aurimasundefined 1 Reply Last reply Reply Quote 0
          • 0nn0undefined
            0nn0
            This post is deleted!
            • Aurimasundefined
              Aurimas @Anon1337
              @Anon1337 anything above 48V is classified as high voltage and potentially life threatening.
              That's why most systems are normally limited to 48V
              Australian design and build large scale 3d printers
              https://aurarum.com.au
