spindle safety?
hi everyone, i have a spindle control using my e0heat and e1heat outputs
as shown here. it all works but i would like to have an overheat safety built in. i was going to use temp1 and fan1 to control a relay when the thermistor on my spindle read too high in case my waterpump quit for some reason. and i have it working but i got thinking that maybe there was a way to use, say e0temp and e1heat(currently being used by spindle control and is turned off with m5 command) thoughts?;spindle control
M950 R0 C"e0heat+e1heat" L0:24000 Q1000
M563 P0 R0 S"Spindle" ; Create tool 0 with spindle 0 and call it Spindle
G10 P0 X0 Y0 Z0
G10 P0 R0 S0Thanks, Rod
@tierod sorry, forgot, its a duet2 using version 3.4.4
