    DHT22 and DuetWifi
    • resam
      resam last edited by
      I'm trying to hook up a DHT22 (well, technically a AM2302) to my DuetWifi.
      I used https://duet3d.com/w2/images/0/0b/Duet2ndGen_connectionsv1.4.png:
      • Expansion Pin 3: 3.3V
      • Expansion Pin 2: GND
      • Expansion Pin 9: Data
      Expansion Pin 9 is labeled "E3_STOP", and according to https://duet3d.com/wiki/DuetWifi_Pinout_table, this is "CS6", and https://duet3d.com/wiki/G-code#M305:_Set_temperature_sensor_parameters says to use that.
      Side note for DC42: there are two E3_STOPs in the pinout table - I guess Pin 98 should be E4_STOP?
      So now I try to setup the virtual heater so I see my DHT22 temp+humidity in DWC. Channel 400 & 401 are Temperature and Humidity of the DHT22.
      I guess this has to be a virtual heater, and 100,101,102 are already taken, so I wanted to start with 103.
      M305 P103 X400 T22 S"Ambient"
      Error: unable to use sensor channel 400 on heater 103
      Unfortunately this error messages doesn't really tell me much. Did I use the wrong pins and the communication failed? Did I use an invalid heater number? Do I need to setup a chamber heater first?
      Any help would be much appreciated!
      • resam
        /me …mhm I should probably add my firmware version to this post...
        /me Doh!
        I'm using 1.19. No wonder it didn't work 😛
        DHT support was added with one of the 1.20 betas.
