Can I run servo motors with duet using external stepper drivers?
  • Hello!
    Can I run servo motors with duet wifi using external stepper drivers?
  • Did you mean with the external stepper driver interface board? If so, yes, if the servo system also has step/dir/en inputs compatible with that board (5VDC signals). But the answer can be very complicated because servos can have specific configuration requirements.
