Cancelled printing file x.gcode, print time was xh ym
  • Hi guys. Any idea why a model would stop printing mid way with the above message? I didn't click cancel. I uploaded the gcode twice in case it was a bad upload. Using RC1 and RC2 did the same thing. It stopped at different points.
    Did you have DWC attached at the time, and if so, were there any popups or messages on the GCode Console page?
  • The only message was canceled printing file. Is how can I further troubleshoot this one? Is there anything in the RC know to cause canceling?
  • Perhaps you could share the gcode and David can simulate it on his test rig?
  • I'm going to run another test. It might have been a mistake on my part. I had the USB plugged into a Raspberry Pi running Repetier Server. I've had problems with it resetting prints before. To be clear, I am printing directly from the Duet board, but the USB plugged into the Pi has caused problems in the past. I'll report back in the morning. Thanks!
    If Repetier Server behaves the same way as Repetier Host then it may be enabling large amounts of debug info, which could be contributing to the problems.
