Solved Relative movement without using G90 and G91
I'm using some nested macros and I'm having issues where, when I'm in relative movment mode, the machine returns to absolute movement becaue I've called a macro that has the G90 command. I'm wondering if it's possible to issue a single relative movement command (eg. G1 Z20) in absolute movement mode without using G90 and G91. Alternatively, is it possible to set the value of inputs[0].axesRelative to a variable value like set inputs[0].axesRelative = {RelativeMoveVar}?
I've tried using M120 and M121 but it also affects feedrate and hotend position.
@Phrayzur when a macro finishes the absolute/relative mode returns to what it was when the macro was called.
@dc42 You are absolutely correct! I don't know why I thought otherwise. Thanks!
