    SE unable to probe portions of bed
    1
    • blt3dpundefined
      blt3dp
      I'm having a problem with the Smart Effector.
      Of course a Delta, running a MB6HC in SBC mode with RRF 3.4.6
      It triggers properly when tapped, is able to perform a G30 without issue, but when I go to do a G32, it is able to probe some spots but not others. It just crashes into the bed.
      The machine is able to move to all the probing points without problem, doesn't seem to be a problem with anything interfering with motion.
      I originally had an SE v2 and my cable bundle too tight and i found it was pulling on the wires. I went ahead and rewired the whole thing, ensured crimps are good and there is plenty of slack and the cables are pretty flexible. I'm pretty sure that's not the issue.
      I just swapped over to a SE v4 thinking it was a problem with the actual SE, maybe some solder joints got broke or something from the previous cable pulling. This forced me to rewire it with the JST PH connector. I bought pre-crimped cables and housing. I connected it all up and it is still the same.
      I thought to adjust the sensitivity but when I send M672 S105:050:255, I don't get flashes on the SE
      But I can send the reset M672 S131:131 and I get the proper 5 flashes
      It's still the same after a reboot.
      Any ideas? Here's my config.g
      ; generated by RepRapFirmware Configuration Tool v2.1.4 on Tue Dec 24 2019 21:00:59 GMT-0800 (PST)
      G90                                                       ; send absolute coordinates...
      M83                                                       ; ...but relative extruder moves
      M550 P"Delta"                                             ; set printer name
      M665 R179.423 L360.250 B150.000 H368.045                  ; set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0                                             ; put your endstop adjustments here, or let auto calibration find them
      M569 P0.0 S1                                              ; physical drive 0.0 goes forwards
      M569 P0.1 S1                                              ; physical drive 0.1 goes forwards
      M569 P0.2 S1                                              ; physical drive 0.2 goes forwards
      M569 P0.3 S1                                              ; physical drive 0.3 goes forwards
      M584 X0.0 Y0.1 Z0.2 E0.3                                  ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                                   ; configure microstepping with interpolation
      M92 X200.00 Y200.00 Z200.00 E415                          ; set steps per mm - Bondtech
      M566 X600.00 Y600.00 Z600.00 E2400.00                     ; set maximum instantaneous speed changes (mm/min)
      M203 X15000.00 Y15000.00 Z2400.00 E2400.00                ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z3000.00 E7200.00                  ; set accelerations (mm/s^2)
      M906 X1700 Y1700 Z1700 E1100 I30                          ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                   ; Set idle timeout
      M208 Z0 S1                                                ; set minimum Z
      M574 X2 S1 P"io1.in"                                      ; configure active-high endstop for high end on X via pin io1.in
      M574 Y2 S1 P"io2.in"                                      ; configure active-high endstop for high end on Y via pin io2.in
      M574 Z2 S1 P"io3.in"                                      ; configure active-high endstop for high end on Z via pin io3.in
      M558 P8 R0.4 C"io4.in+io4.out" H5 F300 T1800              ; set Z probe type to effector and the dive height + speeds
      G31 P100 X0 Y0 Z-0.1                                      ; set Z probe trigger value, offset and trigger height
      M557 R110 S20                                             ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B3590 R2200        ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0 Q10                                    ; create bed heater output on out0 and map it to sensor 0
      M140 H0                                                   ; map heated bed to heater 0
      M143 H0 S120                                              ; set temperature limit for heater 0 to 120C
      M307 H0 R0.241 C905.6 D22.78 S1.00                        ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.060000e-8 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                        ; create nozzle heater output on out1 and map it to sensor 1
      M143 H1 S280                                              ; set temperature limit for heater 1 to 280C
      M307 H1 R3.597 K0.426:0.000 D2.66 E1.35 S1.00 B0          ; disable bang-bang mode for the nozzle heater and set PWM limit
      M950 F0 C"out7" Q75                                       ; create fan 0 on pin out4 and set its frequency
      M106 P0 S0 B0.5 H-1                                       ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out8" Q500                                      ; create fan 1 on pin out8 and set its frequency
      M106 P1 S1 H1 T45                                         ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"out9" Q500                                      ; create fan 2 on pin out9 and set its frequency
      M106 P2 C"LEDs" S0 H-1                                    ; set fan 2 name and value. Thermostatic control is turned off
      M563 P0 D0 H1 F0                                          ; define tool 0
      G10 P0 X0 Y0 Z0                                           ; set tool 0 axis offsets
      M568 P0 R0 S0                                             ; set initial tool 0 active and standby temperatures to 0C
      ; Custom settings
      M575 P1 S1 B57600                                         ; enable support for PanelDue
      M207 S4.5 F2400 Z0.40                                     ; set firmware retraction length, speed and z-lift
      M572 D0 S0.0                                              ; set pressure advance
      M911 S21.9 R22.9 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"    ; set voltage thresholds and actions to run on power loss
      My 3D Printing YouTube Channel
      Better Living Through 3D Printing
      Follow me on Instagram and Twitter
      Instagram
      Twitter
      • blt3dpundefined
        blt3dp
        Could this have been the feedrate too low? Not sure where I got F300 from, but I bumped it to 1200 and it seems to be working.
        Instagram
        Twitter
