    M28 M29 problem
    Gcode meta commands
    • St Tawundefined
      St Taw
      I have a four tool printer and wanting to automate calibration for xy offsets.
      Have created a macro for global variable creation - That OK.
      Have automated tools presented to a camera cross hairs - Jog to location and calculate offsets - Thats OK.
      I can apply the offsets found using G10 command - Thats OK.
      However I want to write the global variables to a file.g Then when the printed is powered up it executes the file and restores the offsets.
      Whilst searching for solutions I find many posts make references to details in docuz which no longer seems to be supported. I have not found an example like the following...
      So my macro to save the global variables is of the form
      M28 "0:/macros/Calibration Values.g" ; Open file
      set global.CameraX=(global.CameraX)
      set global.CameraY=^{global.CameraY}
      set global.CameraZ=global.CameraZ
      set global.T0OffsetX={global.T0OffsetX}
      set global.T0OffsetY={global.T0OffsetY}
      set global.T0OffsetZ={global.T0OffsetZ}
      M29 ; Close File
      The file it makes is
      set global.T1OffsetX={global.T1OffsetX}
      set global.T1OffsetY={global.T1OffsetY}
      set global.T1OffsetZ={global.T1OffsetZ}
      set global.T2OffsetX={global.T2OffsetX}
      set global.T2OffsetY={global.T2OffsetY}
      set global.T2OffsetZ={global.T2OffsetZ}
      set global.T3OffsetX={global.T3OffsetX}
      set global.T3OffsetY={global.T3OffsetY}
      set global.T3OffsetZ={global.T3OffsetZ}
      As you can see I have tried various formats
      So I am not getting the actual values into the file. I want it to be I believe of the form
      set global.CameraX=6.54
      set global.CameraY=96.740
      set global.CameraZ=0
      set global.T1OffsetX=0
      set global.T1OffsetY=2.240
      set global.T1OffsetZ=0.2
      Running
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.6 (2023-07-21)
      Duet WiFi Server Version: 1.27
      Thanks for any help
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @St Taw
        @St-Taw
        You can use the echo command
        https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands#echo-command
        echo >"test.txt" "set global.myGlobal = " ^ global.myGlobal
        St Tawundefined 1 Reply Last reply Reply Quote 1
        • St Tawundefined
          St Taw @OwenD
          @OwenD
          Thanks for quick reply. Have got it working using echo.
          I did see echo before but looked more verbose.
          • dc42undefined dc42 marked this topic as a question
