    [bug] System.NotSupportedException: Specified method is
    DSF Development
    • timschneiderundefined
      timschneider
      While checking the log of the printer that crashes in sbc setup sometimes I found the following.
      The error occured while hammering the DSF<->Duet3 SPI interface with requests via large printjob simulation and quering DSF via DWC to execute M122.
      Jan 04 17:51:15 Meltingplot-MBL-480-vaswsq DuetWebServer[1321]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3] Route matched with {action = "DoCode", controller = "Machine"}. Executing controller action with signature System.Threading.Tasks.Task`1[Microsoft.AspNetCore.Mvc.IActionResult] DoCode(DuetWebServer.Singletons.ISessionStorage, Boolean) on controller DuetWebServer.Controllers.MachineController (DuetWebServer).
      Jan 04 17:51:15 Meltingplot-MBL-480-vaswsq DuetWebServer[1321]: DuetWebServer.Singletons.SessionStorage[0] Session a0b7b52e95b74569b4fcd0fc45803587 started a long-running request
      Jan 04 17:51:15 Meltingplot-MBL-480-vaswsq DuetWebServer[1321]: DuetWebServer.Controllers.MachineController[0] [DoCode] Executing code 'M122'
      Jan 04 17:51:15 Meltingplot-MBL-480-vaswsq DuetControlServer[744]: [error] HTTP: Failed to process code in stage Executed
      Jan 04 17:51:15 Meltingplot-MBL-480-vaswsq DuetControlServer[744]:    System.NotSupportedException: Specified method is not supported.
      Jan 04 17:51:15 Meltingplot-MBL-480-vaswsq DuetControlServer[744]:    at System.Threading.Channels.ChannelReader`1.get_Count()
      Jan 04 17:51:15 Meltingplot-MBL-480-vaswsq DuetControlServer[744]:    at DuetControlServer.Codes.Pipelines.PipelineBase.Diagnostics(StringBuilder builder) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Codes/Pipelines/PipelineBase.cs:line 103
      Jan 04 17:51:15 Meltingplot-MBL-480-vaswsq DuetControlServer[744]:    at DuetControlServer.Codes.ChannelProcessor.Diagnostics(StringBuilder builder) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Codes/ChannelProcessor.cs:line 87
      Jan 04 17:51:15 Meltingplot-MBL-480-vaswsq DuetControlServer[744]:    at DuetControlServer.Codes.Processor.Diagnostics(StringBuilder builder) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Codes/Processor.cs:line 48
      Jan 04 17:51:15 Meltingplot-MBL-480-vaswsq DuetControlServer[744]:    at DuetControlServer.Codes.Handlers.MCodes.Diagnostics(Message result) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Codes/Handlers/MCodes.cs:line 1069
      Jan 04 17:51:15 Meltingplot-MBL-480-vaswsq DuetControlServer[744]:    at DuetControlServer.Codes.Handlers.MCodes.CodeExecuted(Code code) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Codes/Handlers/MCodes.cs:line 1033
      Jan 04 17:51:15 Meltingplot-MBL-480-vaswsq DuetControlServer[744]:    at DuetControlServer.Codes.Pipelines.Executed.ProcessCodeAsync(Code code) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Codes/Pipelines/Executed.cs:line 44
      Jan 04 17:51:15 Meltingplot-MBL-480-vaswsq DuetControlServer[744]:    at DuetControlServer.Codes.Pipelines.PipelineStackItem.<>c__DisplayClass0_0.<<-ctor>b__0>d.MoveNext() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Codes/Pipelines/PipelineStackItem.cs:line 64
      Jan 04 17:51:30 Meltingplot-MBL-480-vaswsq DuetWebServer[1321]: DuetWebServer.Singletons.SessionStorage[0] Session f0e11673864a49f68e1373ccbb7b2557 finished a long-running request
      Jan 04 17:51:30 Meltingplot-MBL-480-vaswsq DuetWebServer[1321]: DuetWebServer.Controllers.MachineController[0] [DoCode] DCS is not started
      Jan 04 17:51:30 Meltingplot-MBL-480-vaswsq DuetWebServer[1321]: Microsoft.AspNetCore.Mvc.Infrastructure.ObjectResultExecutor[1] Executing ObjectResult, writing value of type 'System.String'.
      Jan 04 17:51:30 Meltingplot-MBL-480-vaswsq DuetWebServer[1321]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2] Executed action DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer) in 236398.3322ms
      Jan 04 17:51:30 Meltingplot-MBL-480-vaswsq DuetWebServer[1321]: Microsoft.AspNetCore.Routing.EndpointMiddleware[1] Executed endpoint 'DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer)'
      Jan 04 17:51:30 Meltingplot-MBL-480-vaswsq DuetWebServer[1321]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 POST http://192.168.172.110/machine/code text/plain;charset=UTF-8 4 - 503 - text/plain;+charset=utf-8 236402.9347ms
      Jan 04 17:51:38 Meltingplot-MBL-480-vaswsq DuetWebServer[1321]: DuetWebServer.Singletons.SessionStorage[0] Session f0e11673864a49f68e1373ccbb7b2557 expired
      M122 at the moment DCS crashed from the eventlog
      2024-01-04 17:51:15 === Diagnostics ===
      RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.2 (2023-12-14 10:32:22) running on Duet 3 MB6HC v1.02 or later (SBC mode)
      Board ID: 08DJM-9P63L-DJ3T8-6JKD4-3SJ6K-9A77A
      Used output buffers: 1 of 40 (29 max)
      Static ram: 154844
      Dynamic ram: 88272 of which 4072 recycled
      Never used RAM 95036, free system stack 119 words
      Tasks: SBC(2,nWait,6.6%,404) HEAT(3,nWait,0.0%,324) Move(4,nWait,42.8%,213) CanReceiv(6,nWait,0.0%,942) CanSender(5,nWait,0.0%,334) CanClock(7,delaying,0.0%,342) TMC(4,nWait,5.5%,61) MAIN(1,running,45.0%,103) IDLE(0,ready,0.0%,30), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 01:18:38 ago, cause: power up
      Last software reset at 2024-01-03 15:51, reason: OutOfMemory, Gcodes spinning, available RAM 428, slot 0
      Software reset code 0x41c3 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00435000 BFAR 0x00000000 SP 0x2041b9a0 Task MAIN Freestk 2054 ok
      Stack: 2041808c 00419f61 00000103 2043229c 2043c740 0044659f 00000003 00000000 0000007c 01000003 ffffffff 00000000 00000253 2041bccc 2042bb20 204251b0 204251b0 00471301 00000000 00497caf 0000000a 00000000 00000000 00000000 00000000 00000000 004aea70
      Error status: 0x00
      MCU temperature: min 31.7, current 31.8, max 31.9
      Supply voltage: min 24.1, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.2, max 12.6, under voltage events: 0
      Heap OK, handles allocated/used 99/5, heap memory allocated/used/recyclable 2048/188/40, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min n/a, mspos 200, reads 2920, writes 0 timeouts 0
      Driver 1: standstill, SG min n/a, mspos 808, reads 2919, writes 0 timeouts 0
      Driver 2: standstill, SG min n/a, mspos 744, reads 2919, writes 0 timeouts 0
      Driver 3: standstill, SG min n/a, mspos 584, reads 2919, writes 0 timeouts 0
      Driver 4: standstill, SG min n/a, mspos 584, reads 2920, writes 0 timeouts 0
      Driver 5: standstill, SG min n/a, mspos 4, reads 2920, writes 0 timeouts 0
      Date/time: 2024-01-04 17:51:14
      Slowest loop: 24.27ms; fastest: 0.06ms
      === Storage ===
      Free file entries: 20
      DMs created 125, segments created 38, maxWait 3ms, bed compensation in use: mesh, height map offset -0.015, max steps late 0, ebfmin 0.00, ebfmax 0.00
      no step interrupt scheduled
      Moves shaped first try 78, on retry 4, too short 3, wrong shape 4601, maybepossible 0
      === DDARing 0 ===
      Scheduled moves 2252258, completed 2252233, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === DDARing 1 ===
      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Telnet is idle in state(s) 0
      File* is doing "G1 X560.140991 Y121.342003 E0.064190" in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon* is idle in state(s) 0 0, running macro
      Aux2 is idle in state(s) 0
      File2* is idle in state(s) 0
      Queue2 is idle in state(s) 0
      Q0 segments left 0, axes/extruders owned 0x80000007
      Code queue 0 is empty
      Code queue 1 is empty
      === Filament sensors ===
      check 0 clear 41551178
      Extruder 0: pos 2160.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
      === CAN ===
      Messages queued 8, received 0, lost 0, errs 3722, boc 0
      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 4/0/0
      Tx timeouts 0,0,4,0,0,4 last cancelled message type 30 dest 127
      === SBC interface ===
      Transfer state: 5, failed transfers: 0, checksum errors: 0
      RX/TX seq numbers: 63584/63584
      SPI underruns 0, overruns 0
      State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x258a4
      Buffer RX/TX: 2896/1136-4096, open files: 0
      after DCS restarted
      M122
      Static ram: 154844
      Tasks: SBC(2,ready,3.8%,404) HEAT(3,nWait,0.0%,324) Move(4,nWait,16.8%,213) CanReceiv(6,nWait,0.0%,942) CanSender(5,nWait,0.0%,334) CanClock(7,delaying,0.0%,342) TMC(4,nWait,6.9%,61) MAIN(2,running,72.4%,103) IDLE(0,ready,0.0%,30), total 100.0%
      Last reset 01:30:01 ago, cause: power up
      Error status: 0x00
      MCU temperature: min 31.6, current 32.1, max 32.3
      Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 11.7, current 12.2, max 13.0, under voltage events: 0
      Heap OK, handles allocated/used 99/4, heap memory allocated/used/recyclable 2048/188/84, gc cycles 0
      Driver 0: standstill, SG min n/a, mspos 200, reads 58753, writes 0 timeouts 0
      Driver 1: standstill, SG min n/a, mspos 808, reads 58753, writes 0 timeouts 0
      Driver 2: standstill, SG min n/a, mspos 744, reads 58753, writes 0 timeouts 0
      Driver 3: standstill, SG min n/a, mspos 584, reads 58753, writes 0 timeouts 0
      Driver 4: standstill, SG min n/a, mspos 584, reads 58752, writes 0 timeouts 0
      Driver 5: standstill, SG min n/a, mspos 4, reads 58752, writes 0 timeouts 0
      Date/time: 2024-01-04 18:02:38
      Slowest loop: 34.87ms; fastest: 0.05ms
      === Storage ===
      DMs created 125, segments created 38, maxWait 54ms, bed compensation in use: mesh, height map offset -0.015, max steps late 0, ebfmin 0.00, ebfmax 0.00
      Moves shaped first try 36298, on retry 13009, too short 24420, wrong shape 1424794, maybepossible 4988
      === DDARing 0 ===
      Scheduled moves 4235707, completed 4235707, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === DDARing 1 ===
      File* is idle in state(s) 0
      Q0 segments left 0, axes/extruders owned 0x80000003
      check 0 clear 46345336
      === CAN ===
      Messages queued 6149, received 0, lost 0, errs 3242235, boc 0
      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 3416/0/0
      Tx timeouts 0,0,3416,0,0,2733 last cancelled message type 4514 dest 127
      RX/TX seq numbers: 2616/2616
      Buffer RX/TX: 0/0-0, open files: 0
      === Duet Control Server ===
      Duet Control Server version 3.5.0-rc.2 (2023-12-18 12:42:49)
      Failed to deserialize the following properties:
      - MoveSegmentation -> Int32 from 2.0
      Daemon:
      >> Doing macro daemon.g, started by system
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
      Full transfers per second: 198.67, max time between full transfers: 64.9ms, max pin wait times: 43.0ms/33.7ms
      Codes per second: 741.41
      Maximum length of RX/TX data transfers: 7392/3356
      droftartsundefined chrishammundefined 2 Replies Last reply Reply Quote 1
        droftarts administrators @timschneider
        @timschneider One for @chrishamm
        • chrishammundefined
          chrishamm administrators @timschneider
          @timschneider Thanks for reporting this, it should be fixed now.
          Duet software engineer
          • timschneiderundefined timschneider referenced this topic
