    M572 doesn't report parameters?
    • DocTruckerundefined
      DocTrucker
      If enter M572 into the gcode console in webcontrol should I see the set parameters returned?
      Thanks!
      • deckingmanundefined
        deckingman
        It works for me. I'm using the following:
        Firmware Name: RepRapFirmware for Duet Ethernet
        Firmware Electronics: Duet Ethernet 1.0 + DueX5
        Firmware Version: 1.20RC2 (2017-12-13)
        Web Interface Version: 1.20-RC3
          In firmware 1.20, M572 with no parameters reports the pressure advance of every extruder. In earlier firmwares, M572 D0 will report the pressure advance of extruder 0, and so on.
            DocTrucker
            Ah ok, missed the D0. Thanks for the guidance.
            Should have said which machine I'm working on:
            Duet v0.6, most recent compatible firmware.
              There is a 1.20RC3 build available for the Duet 06/085.
                DocTrucker
                Great, thanks. I'll take a look after I've printed a carrier to bolt the titan to the top of the belt carrage!
                Getting challenged by these strings and with TPU I think the pressure advance/retract is only compressing or decompressing the filament in the bowden.
