24V Automotive Relays ok for PS_ON on Duet3?
Hello. Just checked the schematics and on a 1.01 Duet3 main board the ps_on pin is drained to ground through a AO3400A MOSFET. This has a max drain to source voltage of 30V. I assume 24V automotive relays are fine so long as there is a flyback diode?
undefined Phaedrux marked this topic as a question
@DocTrucker Correct.
undefined DocTrucker has marked this topic as solved
@dc42 are there any potential issues if the 24V is on the board before the 5V? Should the SBC Duet systems boot order be: Screen, Raspberry Pi, then Duet?
