Pause command working late....
Hi, I am using duet2 Wi-Fi based controller for 3d printing application to print paste.
after giving pause command, printer does not stop instantly. instead of that it travel some distance and then stop.can some please guide me how to tackle this problem.
I want it to stop printing just after giving pause signal to it.
@India you could add segmentation. So
M669 T1 S1
should improve the pausing ability -
@jay_s_uk thanks for your reply sir,
Where should i include this command , like in configuration file (config.g) or within pause.g file.
@India if you want this behaviour on all builds ran on this specific machine add it to your config file. You could also add it to the custom gcode your chosen slicer puts at the beginning of a build file.
Read through the detail for M669 here:
