    Unable to heat or extrude
    • Cumulus7undefined
      Cumulus7
      Hello everybody,
      i am having trouble to set up the Duet for my Hypercube Evolution.
      Not working for me in WebControl
      • Set temperatures for Bed and Hotend.
      • -> "chamber heater not defined" (???) and Java Script error
      • Extruder Control
      • -> no reaction at all - even after "M302 P1"
      What is working:
      • Homing
      • Heating Bed manually by G-Code
      • Using Extruder-Motor by G-Code (after using M302 P1 to enable cold-extrusion)
      What catches my eyes is that the text "Heater1" etc. is not colored in WebControl as in the example screenshots i saw.
      I would be very gratefull for any help.
      Greetings,
      Markus
      As much additional information as possible 🙂 :
      Software Versions:
      Complete Web-Control-Window:
      Pushing the "extrude" button in the "Extrude Control" does nothing…..
      Trying to heat Heater1 using the dropdown selection box next to "Heater 1":
      When trying to heat the bed using Button next to "Heater 0"
      My config.g:
      [[language]]
      ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
      ; generated by RepRapFirmware Configuration Tool on Sun Dec 17 2017 22:14:21 GMT+0100 (Mitteleuropäische Zeit)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M667 S1 ; Select CoreXY mode
      M208 X300 Y300 Z280 S0 ; Set axis maxima
      M574 X1 Y1 Z1 S1 ; Set active high endstops
      ;M558 P0 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
      ;G31 P600 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
      M557 X15:285 Y15:285 S20 ; Define mesh grid
      M350 X16 Y16 Z16 E16 I0 ; Configure microstepping without interpolation
      M92 X80 Y80 Z405 E95 ; Set steps per mm
      M203 X9000 Y9000 Z1200 E4800 ; Set maximum speeds (mm/min)
      M201 X700 Y700 Z250 E250 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 1
      M563 P1 D0 H1 ; Define tool 1
      G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
      M550 PHEVO ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M106 P1 S1 I0 F500 H T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      T1 ; Select first tool
      Photo:
      Hypercube Evolution with DuetWifi: 90% build - cable management missing :-)
        I suspect that you have a mixture of versions of DWC files being run. Please move the SD card to a PC, delete or rename the existing /www folder on it, create a new one, then extract the DWC 1.13 files to it from the zip file. Check that the SD card folder structure is as shown at https://duet3d.com/wiki/SD_card_folder_structure, then safely remove the SD card, put is back into the Duet and start the Duet. Clear temporary internet files in your browser, then connect.
        • Cumulus7undefined
          Cumulus7
          THX David.
          Even renaming the old www folder to www_old and copying a "new" 1.19.3 WC did not help.
          Then i upgraded to 1.20RC3 and noticed that DWC did not upgrade to 1.20 even though the files were correctly uploaded.
          I completly deleted the old www folders (www and www_old) and created a new one with the 1.20RC3 contents… now it works.
          Thumbs UP
          I am still trying to figure out why the SD-card contents was not recocgnized correctly though….
