    How to remove STOP button from PanelDue?
    PanelDue
    • KennethRundefined
      KennethR
      I have a Panelduo running on a V2.03 Duet2 Wifi. I would like to remove the stop button from the screen as I have a physical emergency stop button(it's a huge 500X500X800mm clay printer). My reason for the change is that if the button by accident is hit, then a week long print job may be lost. It happened to us once, but luckily "only" 1,5 days of work was lost.
      I understand that I would need to compile a new firmware, which would be V1.25 if I did my homework correctly, but can anyone point me to a guide on what I would have to change in the source files?
      BR Kenneth
      MJLewundefined 1 Reply Last reply Reply Quote 0
      • MJLewundefined
        MJLew @KennethR
        @KennethR If it was a problem on my 3d printer I would print a frame for the panel that covered up the button in question but, yes, removing it in software would be better.
