Changing T while waiting to reach from gcode failing
When I start a job and try to modify the bed or hot-end temperatures fed from the gcode file the web control allows to type it but does not set it.
The Jayo S8 original board allowed to change temperatures at any point.
Am I missing something?
You'd need to type and hit enter on each field for the new temp to be applied. if you do this while the heater is still heating up, the update may show with a delay.
