Software version 3.5.0-rc.3 released
On behalf of the Duet3D team I am pleased to announce the availability of the third release candiate for v3.5.0. Please consider testing this build as it is very likely the last candidate before the final release of stable version 3.5.
Highlights of this particular versions include:
- Improvements in the Ethernet backend of RepRapFirmware
- Increase of free RAM on the Duet 2 series
- Added DSF support for Debian Bookworm (latest RPi OS version)
- Various bug fixes
Please read the upgrade notes to avoid potential issues on upgrade:
Users in standalone mode can obtain the latest version from here. Users running in SBC mode can update using the
apt update
/apt upgrade
appraoach as usual.If you encounter any more issues, please open a new thread starting withÂ
[3.5.0-rc.3]
in the title.PS: A new experimental Bookworm-based DuetPi image will follow very soon. This version will provide automatic online upgrades for DSF/RRF via
M997 S2
as well. -
undefined chrishamm pinned this topic
undefined droftarts referenced this topic
@chrishamm, the release notes for RRF say:
[Duet 2] [Duet Maestro] The number of HTTP responders has been reduced from 4 to 3. This should not matter unless you have HTTP connections to the Duet open on several PCs or in several browser tabs, or you upload files from two or more PCs or browser tabs concurrently.
I regularly use/monitor/operate my Duet2 based printers from two different computers. The tabs are always open. On occasion I might have an additional instance/tab open. I only interact with the Duet2 from one computer at a time. Each browser tab can have a web video stream running in it to monitor print progress.
Can you tell me if the change of HTTP responders has any effect on my current way of using the web connection? Do I need to change anything in my procedures? If I went to three different computers, would things still work? What would I see or what would happen if I ran into a problem with this?
@jens55 You may get connection aborts if all responders are busy and the sockets can't queue any more incoming connections. If you do, please report back.
@chrishamm FWIW, working fine on my RailCore with PA and IS. Printed 10-15 hours so far. Heightmap when skipping points still looks funny :).
Edit: I'm running standalone mode.
undefined chrishamm unpinned this topic
