1LC Multiple Disconnects
@curieos thanks for the photos. If the hotspot is that area indicated by the red circle and cross, that's diode D5 which feeds the output of the 12V regulator to the VOUT pin of the OUT1 and OUT2 connectors. It would be odd if that component was generating a lot of heat. What I suspect is that the surrounding area is at more or less the same temperature and the heat is coming from both the 12V buck regulator and the 5V linear regulator.
Can you confirm that you are not using the IO_0 connector to power anything? It's not connected in your photo.
It's nor normal for the Status lights to be off and the power lights to be on. That condition should only occur briefly after power up when the crystal oscillator is starting and the board is booting up. So I suspect that the processor has gone into some sort of locked up state that even the watchdog timer can't recover from, or the oscillator has stopped. The only reasons I can think of for it locking up in this way are static discharge, a a loss of power that wasn't quite enough to cause a full shutdown, or a faulty tool board. We know that static discharge is common on hot ends, but we haven't know of it affecting a TOOL1LC in this way. Nevertheless, please ensure that the hot end metalwork is grounded. You can ground it to one of the mounting screws of the tool board.
What was the reason for putting a heatsink on top of the MCU? How did you attach it? The MCU generates very little heat and certainly doesn't need a heatsink. The components that generate heat on the tool board are the 5V linear regulator, the TMC2209 driver (depending on motor current), and the 12V buck regulator (depending on VIN voltage and the current draw from OUT1 and OUT2).
I'd suggest that we replace your tool board, but you said you have already swapped it for a different one.
@dc42 Correct, IO_0 is not connected. You said OUT0 earlier, which was confusing.
The hotend metalwork and toolboard are connected via the toolplate. The hotend has continuity with the plate, and the toolboard has a connection to the toolplate via the green wire in the upper right corner.
I put the heatsink on the MCU because I noticed the previous toolboard's MCU was very hot to the touch before I swapped it out. I put it on that toolboard, and then transferred it to the new one when I swapped it out. Originally I thought it was just an overheating issue. The heatsink has preattached thermal adhesive. Not shown is a thin ceramic heatsink on the rear of the toolboard, mounted with some 3M thermal transfer adhesive. That covers the MCU and stepper driver.
@dc42 Any other suggestions? I just replaced the power cable for the toolboard with brand new wire and this issue is still occurring.
@dc42 I tried updating that machine to 3.5 rc3 and the issue persists. What physically can cause a 1LC to lock up until a full power cycle?
Are the mainboard and toolboard powered from a common PSU? If not, are the grounds of the PSU tied together?
@Phaedrux Yes, all of the 24V system is connected to one supply.
@dc42 I'm reporting in that this issue is still occurring. I have changed out the CAN data and power cable runs to this toolhead yet again, in fact the run is a little different this time. The tool distribution board is now mounted to the gantry, so the power and data cables are shorter than before.
The same toolboard locks up at around the same point in any print I've tried, typically around the 1 hour mark. It's been replaced once already. The board does not recover until a full power cycle of the machine is performed.
I have an M122 output from this latest event:
=== Diagnostics === RepRapFirmware for Duet 3 MB6XD version 3.5.0-rc.3 (2024-01-24 17:59:29) running on Duet 3 MB6XD v1.01 or later (SBC mode) Board ID: 0JD2M-999AL-D25SW-6JKD0-3S06R-95ZB1 Used output buffers: 1 of 40 (40 max) === RTOS === Static ram: 153600 Dynamic ram: 92392 of which 0 recycled Never used RAM 96400, free system stack 122 words Tasks: SBC(2,ready,14.4%,407) HEAT(3,nWait 6,0.2%,322) Move(4,nWait 6,8.7%,213) CanReceiv(6,nWait 1,28.2%,770) CanSender(5,nWait 7,0.1%,325) CanClock(7,delaying,0.1%,346) MAIN(2,running,47.7%,444) IDLE(0,ready,0.6%,30), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 03:30:24 ago, cause: power up Last software reset at 2024-03-07 09:55, reason: User, Gcodes spinning, available RAM 95784, slot 0 Software reset code 0x6003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 MCU temperature: min 30.9, current 48.1, max 49.9 Supply voltage: min 25.8, current 26.0, max 26.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0 Heap OK, handles allocated/used 99/38, heap memory allocated/used/recyclable 2048/1388/712, gc cycles 4 Events: 3 queued, 3 completed Driver 0: ok Driver 1: ok Driver 2: ok Driver 3: ok Driver 4: ok Driver 5: ok Date/time: 2024-03-14 14:58:02 Slowest loop: 1000.79ms; fastest: 0.05ms === Storage === Free file entries: 20 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 31, maxWait 3494446ms, bed compensation in use: none, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 9729, on retry 4260, too short 16445, wrong shape 17913, maybepossible 1481 === DDARing 0 === Scheduled moves 59311, completed 59311, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 4], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC* is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause* is idle in state(s) 0 File2* is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000000 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 0 clear 0 Extruder 0: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0 Extruder 1: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0 === CAN === Messages queued 189586, received 21212642, lost 0, errs 586337, boc 48 Longest wait 208ms for reply type 6033, peak Tx sync delay 1409, free buffers 50 (min 47), ts 63121/63096/0 Tx timeouts 0,0,0,0,0,0 === SBC interface === Transfer state: 5, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 57670/57670 SPI underruns 0, overruns 0 State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2600c Buffer RX/TX: 0/0-0, open files: 0 === Duet Control Server === Duet Control Server version 3.5.0-rc.3 (2024-01-26 12:34:19) File+ProcessInternally: > Busy Failed to deserialize the following properties: - Board -> BoardState from "timedOut" Code buffer space: 4096 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 1 Full transfers per second: 39.34, max time between full transfers: 73.4ms, max pin wait times: 69.8ms/18.6ms Codes per second: 13.12 Maximum length of RX/TX data transfers: 5088/3144
I'm going to try disconnecting all connections to the board except for the endstop required for homing, and then I'll run another print. Let me know if there's any additional steps I should try.
edit: Here's the M122 for the board that locked up after a restart
Diagnostics for board 21: Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.3 (2024-01-24 17:55:14) Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25) All averaging filters OK Never used RAM 2936, free system stack 104 words Tasks: Move(3,nWait 7,0.0%,135) HEAT(2,nWait 6,0.2%,127) CanAsync(5,nWait 4,0.0%,51) CanRecv(3,nWait 1,0.0%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,delaying,3.4%,53) MAIN(1,running,91.7%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.6%,112), total 100.0% Owned mutexes: Last reset 00:02:17 ago, cause: power up Last software reset at 2024-02-01 11:32, reason: HardFault, available RAM 2016, slot 0 Software reset code 0x0060 ICSR 0x00000003 SP 0x20002f08 Task MAIN Freestk 813 ok Stack: 200048c8 00000000 00000001 4aa36799 00000000 0000f3cb 4aa36798 21000000 20001488 0000f00d a5a5a5a5 0080bdc1 00000089 000001f4 20001ce0 0001285f 00000000 00000000 20004370 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 Driver 0: pos 0, 404.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 2957, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, segs 0, step errors 0, maxLate 0 maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 0.00 Peak sync jitter 0/4, peak Rx sync delay 207, resyncs 0/0, no timer interrupt scheduled VIN voltage: min 26.7, current 26.8, max 26.8 MCU temperature: min 34.8C, current 41.4C, max 41.4C Last sensors broadcast 0x00018004 found 3 35 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 2530, send timeouts 0, received 2038, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 Accelerometer: LIS3DH, status: 00 I2C bus errors 0, naks 3, contentions 0, other errors 0 === Filament sensors === Interrupt 5726621 to 0us, poll 6 to 542us Driver 0: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
@curieos said in 1LC Multiple Disconnects:
The only things that changed between the toolboard working fine and it having issues were a grounding wire run to the toolhead plate, and a new CAN cable with crimped terminations instead of the soldered pigtails.
What is the grounding wire connected to? If it's connected to mains ground, is Duet ground also connected to mains ground?
Is the extruder motor body also grounded?
@dc42 The grounding wire is connected to earth ground, and it screws into an aluminum toolhead plate. The grounding wire connected to the 1LC via one of the mounting holes is also connected to the toolhead plate. I can see if there's a low impedance connection between DC ground and earth ground when I get into work today, I assume this would be an issue.
The extruder motor body is physically touching said toolhead plate, and the mounting screws go through the toolhead plate. The toolhead plate is anodized, so it's not the most solid connection, but I've checked with a multimeter and there is continuity. The extruder is an LGX Pro, so the hotend mount is made of anodized aluminum, and the hotend metalwork is connected to the toolhead plate through the extruder mounting. I've checked with a multimeter and it detects continuity. If this isn't good enough I can run a discrete grounding wire from the toolhead plate to the coldside of the hotend.
@dc42 I may have fixed it.
Turns out on this unit, there was a zero impedance connection between DC ground and Earth ground. I found the culprit, the cutout for the ethernet extension plugged into the pi was made upside down. This meant the shielding on the plug was in contact with the aluminum frame panel. The panel is powder coated, but it appears the coating wore away in this area. I flipped it upside down and now the grounds aren't shorted.
I ran a 6 hour print last night and there were no issues. The longest I've seen it go without locking up was 3-4 hours, so I think this means the problem is solved. I'm running a slightly longer print (22.5 hours) now, so that will definitely be definitive.
@curieos I'm glad you appear to have found the cause! Ground loops can cause various odd behaviour, just like ESD can.
I'll mark this thread as solved but feel free to revert it if the problem recurs.
undefined dc42 has marked this topic as solved
