    Updating Duet3 via DWC even when using SBC
    Firmware installation
    1
    • BlueDustundefined
      BlueDust
      I tried to update my Duet3 6HC with SBC and it appears to not work.
      DWC says version 3.4.6, DSF says version 3.4.6, but Firmware says 3.4.5.
      I am trying to install the Input Shaping Plugin, and it fails because Plugin service has not started.
      I am guessing its failing because the firmware is wrong, or at least its low hanging fruit to fix....
      I tried to update the Duet3 via DWC but it stated only update if support tells you to do so, otherwise only update via SBC.
      2 problems
      1. How do I update The Duet3?
      2. If updating the Duet3 doesn't fix the plugin service, how do I start it?
      Thanks!
      Fun, that 3 letter word with "u" in the middle.
      BlueDustundefined 1 Reply Last reply Reply Quote 0
      • BlueDustundefined
        BlueDust @BlueDust
        Kept looking for info on the 1st problem...
        Found this and fixed it.
        https://forum.duet3d.com/topic/34638/sudo-apt-dist-upgrade-doesn-t-update-main-board
        I am still getting the error about the plug in service not running....
        But again will keep looking for a fix for this.
        • BlueDustundefined
          BlueDust @BlueDust
          M122
          RepRapFirmware for Duet 3 MB6HC version 3.4.5 (2022-11-30 19:35:23) running on Duet 3 MB6HC v1.01 (SBC mode)
          Board ID: 08DJM-956L2-G43S4-6JTDJ-3SD6S-9S5YD
          Used output buffers: 4 of 40 (18 max)
          Static ram: 152760
          Dynamic ram: 67164 of which 16 recycled
          Never used RAM 130732, free system stack 194 words
          Tasks: SBC(resourceWait:,0.5%,476) HEAT(notifyWait,0.0%,322) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,740) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,333) TMC(notifyWait,7.7%,91) MAIN(running,90.0%,1227) IDLE(ready,1.8%,30), total 100.0%
          Owned mutexes: HTTP(MAIN)
          Last reset 00:20:22 ago, cause: power up
          Last software reset at 2024-01-26 15:09, reason: User, Platform spinning, available RAM 125540, slot 1
          Software reset code 0x0000 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          Step timer max interval 134
          MCU temperature: min 19.7, current 35.4, max 35.5
          Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min 0, mspos 8, reads 13784, writes 14 timeouts 0
          Driver 1: standstill, SG min 0, mspos 8, reads 13784, writes 14 timeouts 0
          Driver 2: standstill, SG min 0, mspos 8, reads 13787, writes 11 timeouts 0
          Driver 3: standstill, SG min 0, mspos 8, reads 13787, writes 11 timeouts 0
          Driver 4: standstill, SG min 0, mspos 8, reads 13784, writes 14 timeouts 0
          Driver 5: standstill, SG min 0, mspos 8, reads 13784, writes 14 timeouts 0
          Date/time: 2024-01-29 18:14:27
          Slowest loop: 24.21ms; fastest: 0.03ms
          === Storage ===
          Free file entries: 10
          DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters 2 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
          Segments left: 0
          Movement lock held by null
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty
          === CAN ===
          Messages queued 13233, received 268, lost 0, boc 0
          Longest wait 2ms for reply type 2010, peak Tx sync delay 61138, free buffers 50 (min 49), ts 6112/6098/0
          Tx timeouts 0,0,13,0,0,7 last cancelled message type 30 dest 127
          === SBC interface ===
          Transfer state: 5, failed transfers: 0, checksum errors: 0
          RX/TX seq numbers: 47168/47168
          SPI underruns 0, overruns 0
          State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2ad1c
          Buffer RX/TX: 0/0-0, open files: 0
          === Duet Control Server ===
          Duet Control Server v3.4.6
          Code buffer space: 4096
          Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
          Full transfers per second: 27.49, max time between full transfers: 1723.4ms, max pin wait times: 1760.6ms/9.3ms
          Codes per second: 0.04
          Maximum length of RX/TX data transfers: 3487/876
          • BlueDustundefined
            BlueDust @BlueDust
            • BlueDustundefined
              BlueDust @BlueDust
              • BlueDustundefined BlueDust referenced this topic
              • BlueDustundefined BlueDust marked this topic as a question
              • BlueDustundefined BlueDust has marked this topic as solved
