    "sudo apt dist-upgrade" Doesn't update main board?
    Firmware installation
    • DocTruckerundefined
      DocTrucker
      Hi all. I followed the instructions for SBC connected duet upgrades and it doesn't appear to have upgraded the Duet3 main board. I am getting compatability warnings and the board appears to be on 3.3.
      How should I upgrade?
      • DocTruckerundefined DocTrucker marked this topic as a question
        jay_s_uk @DocTrucker
        @DocTrucker try sending M997 and see if that updates the board.
        If not, you could either briefly run the board in standalone mode and update it that way or use BOSSA
        DocTruckerundefined 1 Reply Last reply Reply Quote 1
          DocTrucker @jay_s_uk
          @jay_s_uk that got it, thanks.
          Can someone update the documentation to add a note relating to this to step 6?
          https://docs.duet3d.com/User_manual/Machine_configuration/SBC_setup
          jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
            @DocTrucker on a typical install, using M997 shouldn't be needed and the SBC should do it all for you. I don't know why it failed in your case
            • DocTruckerundefined DocTrucker has marked this topic as solved
              Phaedrux Moderator @DocTrucker
              @DocTrucker said in "sudo apt dist-upgrade" Doesn't update main board?:
              @droftarts Not a bad idea?
              • BlueDustundefined BlueDust referenced this topic
