    Plugin failed to install - Service is not Started
    Plugins for DWC and DSF
    1
    • BlueDustundefined
      BlueDust
      Plugin Service hasn't started
      I initially asked the question here as my 2nd issue, as I thought fixing the 1st issue might fixed the 2nd, I asked in the Firmware category first.
      https://forum.duet3d.com/topic/34832/updating-duet3-via-dwc-even-when-using-sbc
      But as it didn't fix it I am here asking for help.
      I am trying to install the Input Shaping plugin, and I get an error...
      It doesn't seem to make a lot of sense to me, as I do have other plugins running. You can see both the error and that there are other plugins running in the picture.
      Thanks for the help!
      Fun, that 3 letter word with "u" in the middle.
      • BlueDustundefined
        BlueDust
        It looks like I figured it out....
        When I tried to install the plugin service it said it was already installed... (which makes sense as there were already other plug ins installed/working).
        I found this was missing from cmdline.txt.... and I just needed to run this one line to fix it...
        sudo bash -c 'echo " lsm=apparmor" >> /boot/cmdline.txt'
        Sources...
        https://forum.duet3d.com/topic/28190/error-trying-to-install-input-shaping-plugin-according-to-docs?_=1706571988581
        https://github.com/Duet3D/DuetSoftwareFramework/wiki/Changelog-DSF-3.x#version-330
        • BlueDustundefined BlueDust marked this topic as a question
        • BlueDustundefined BlueDust has marked this topic as solved
