Can't connect to Duet board: Network scan failed
  • undefined
    tylersuard
    Can't connect to DWC. When I first bought my Duet, everything worked fine. After a few months, I noticed that I had to connect to the board with a USB cable and turn the network connection off and on again (M552 S-1 and then M552 S1) a few times before it would connect to my internet, but I figured that was just an annoyance I can put up with. Now, today, my trick of turning the network connection off and on again is not working, and I am getting this:
    WiFi module is idle
    Error: WiFi module reported: network scan failed
    WiFi module is idle
    WiFi module is idle
    Repeated thousands of times, and then:
    WiFi module is connected to access point , IP address 255.255.255.255
    Which of course does not work.
    • undefined
      Let's stick to your existing thread.
      https://forum.duet3d.com/topic/33301/solution-can-t-connect-to-duet-web-control?_=1706586658445
      • undefined Phaedrux locked this topic 30 Jan 2024, 04:11
      1 out of 2
