    Extrusion
    Filament Monitor
    • Duet_loverundefined
      Duet_lover
      Hi
      I am facing problem in running two extruder for printing mixed material.
      After sending g code
      G1 E100:50 F2400
      And also
      G1 X100 E100:50
      directly from command, extrusion taking place.
      Fallowing this I am uploading G code file 📁📁 I am trying to print a single line , it showing error like this
      ![alt text]([image url](link urlIMG-20240130-WA0002.jpg ))
      In which it saying multiple parameter in E with g code is not supported with absolute mode
      G90
      Then after I tried to write g code in incremental mode by adding line
      G91
      G0 X50 Y0 F2400
      G1 X100 E100:50 F2400
      Even it is showing same problem.
      Any one can guide me for the same
      Thanks
      • oliofundefined
        oliof
        set relative extrusion mode by adding M83 to your config.g
        Duet_loverundefined 1 Reply Last reply Reply Quote 0
          Duet_lover @oliof
          @oliof thank you sir ,
          I will try it.
          • DocTruckerundefined
            DocTrucker
            It also may be worth checking out "M567: Set tool mix ratios".
            https://docs.duet3d.com/en/User_manual/Reference/Gcodes
              Duet_lover @DocTrucker
              @DocTrucker thanks you
