    Printer name as global variable used with M550
    Gcode meta commands
    • Yaoundefined
      Yao
      hi, does anyone know how i can use multiple global variables into one string with the M550 (printername)?
      global AccName="Myprinter"
      global serial="467"
      How to combine these two behind the: M550 P.....
      Thanks!
      • T3P3Tonyundefined
        T3P3Tony administrators @Yao
        @Yao Have a look at string concatenation operator here:
        https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands#binary-infix-operators
        e.g.
        M550 P{global.AccName^global.serial}
        www.duet3d.com
        Yaoundefined 2 Replies Last reply Reply Quote 1
        • Yaoundefined
          Yao @T3P3Tony
          @T3P3Tony it just returns the name to : My Duet...
          I cant even get
          M550 P{global.AccName}
          to work...
          i dont get it.
          • Yaoundefined
            Yao @T3P3Tony
            @T3P3Tony
            my bad.
            line was before global !!!!🙄
            T3P3Tonyundefined 1 Reply Last reply Reply Quote 1
            • T3P3Tonyundefined
              @Yao i tend to use echo to test stuff from the console before trying it in an actual macro which helps debug.
              www.duet3d.com
              Yaoundefined 1 Reply Last reply Reply Quote 1
              • Yaoundefined
                Yao @T3P3Tony
                @T3P3Tony the echo worked... but in the config.g that M550 was in the wrong location...
                I use an external file with all globals, this was loaded after the M550 command,
                ...I was not paying attention...
                • dc42undefined dc42 marked this topic as a question
