    Duet Web Control - Touch screen nightmare!
    Duet Web Control wishlist
    1.2k
    • Merlinundefined
      Merlin
      I'm driving a Delta printer based on DC42 large delta but with 'Midi' dimensions including 300mm DIA bed and 24V heated bed, powered by Duet Wifi.
      I'm using a 10" Asus Android touch screen Tablet running Duet Web Control, and a Volcano type hot end.
      So 9 hours into a 14 hour print I hit pause to tidy away a NIU secondary print fan that was about to foul the Z drive belt.
      Then my clumsy large finger hit the 'Cancel' instead of the 'Resume' button !!
      Please, Please can these buttons have a larger separation?
      Better still pop up a "Confirm Y/N" window when 'Cancel' is touched/clicked.
      • DuetUserundefined
        DuetUser
        You are right it's easy to incidentally cancel the print.
        If you'd like a confirmation window after hitting cancel just replace lines 349 - 352 in the file www/js/interface.js which are:
        [[language]]
        $("#btn_cancel").click(function() {
        	sendGCode("M0 H1");	// Stop / Cancel Print, but leave all the heaters on
        	$(this).addClass("disabled");
        ```with these:
        [[language]]
        showConfirmationDialog(T("Cancel print"), T("This will irrevocably cancel your print.
        Are you REALLY sure you want to do this?"),
        function() {
        Then tell me if it works.
        peter
        • T3P3Tonyundefined
          T3P3Tony administrators
          If you are using a DuetWifi you need to package up DWC after making any changes. See the readme file here:
          https://github.com/chrishamm/DuetWebControl
          www.duet3d.com
          • Merlinundefined
            Merlin
            Thanks.
            I'll try that and let you know how I get on.
