    Record printing temperature and humidity
    Gcode meta commands
    • amimafeundefined
      amimafe
      I am trying to edit daemon.g to make a log of a DHT22 sensor among other data. (Re: while-loop to track temperature)
      I manage to create the .csv file but I always get the same error on line 5:
      Error: in file macro line 5 column 72: meta command: expected an expression
      I am missing some number between the []?
      I attach the code of my daemon.g:
      if !exists(global.logTemps)
          global logTemps = false
      while global.logTemps ==true && job.file.fileName != null
          echo >>{"0:/templog/templog.csv"} {state.time}^","^{sensors.analog[].dht22.lastReading}^","^{sensors.analog[].dht-humidity.lastReading}
          G4 S1
      Thanks!
      • oliofundefined
        oliof @amimafe
        @amimafe try 0 inside the square brackets
        amimafeundefined 1 Reply Last reply Reply Quote 0
        • amimafeundefined
          amimafe @oliof
          @oliof
          Thanks for your quick response.
          Daemon.g modified:
              echo >>{"0:/templog/templog.csv"} {state.time}^","^{sensors.analog[0].dht22.lastReading}^","^{sensors.analog[0].dht-humidity.lastReading}
              G4 S1
          I get the following error:
          Error: in file macro line 5 column 57: meta command: reached null object before end of selector string
          • oliofundefined
            oliof @amimafe
            @amimafe I think you need to drop the .dht22
            • amimafeundefined
              amimafe @oliof
              @oliof
              Gracias por tu ayuda. Me diste una pista de cual era el fallo y finalmente lo he podido solucionar. Era un error al indicar el número de sensor que quería.
              Revisé el archivo config.g y lo configuré correctamente.
              Declaración de los sensores en config.g:
              ;DHT Sensor on Temperature Daughterboard SPI CS1 pin
              M308 S10 P"0.spi.cs1" Y"dht22" A"Temperatura" ; define DHT22 temperature sensor
              M308 S11 P"S10.1" Y"dht-humidity" A"Humedad [%]" ; Attach DHT22 humidity sensor to secondary output of temperature sensor
              daemon.g:
                  echo >>{"0:/sys/templog/templog.csv"} {sensors.analog[10].lastReading}^","^{sensors.analog[11].lastReading}
                  G4 S30
              • amimafeundefined amimafe marked this topic as a question
              • amimafeundefined amimafe has marked this topic as solved
