Solved Issue with downloading firmware
Hello everyone,
I'm have an issue in downloading the firmware, if I start a fresh clean config. Here are some pre-info to help, I'm using a Duet 3 6HC motherboard, Raspberry pi 4 (SBC Mode) and a toolboard 1LC. I used the 3.4 and 3.5 config tool, once i start a fresh clean start of entering the required information and then click finish. It only shows the files that are needed for the SYS folder, the www and firmware folder are not shown. But if I refresh the screen they show up, but the problem to that is I get a config file that is not what pre-entered, it looks like a fresh screen when you first access it. I tried this on a Windows and Linux PC and get the same thing.Regards
@press1now Firmware and WWW files already come with the SBC installation, so there is no need to install them via a config bundle. See here how to upgrade the SBC firmware and web interface if necessary.
undefined T3P3Tony marked this topic as a question
undefined T3P3Tony has marked this topic as solved
