    Assistance with resetting DUET2 from back up files request.
    CNC
    • Feathertreecncundefined
      Feathertreecnc
      Hello peeps, newbie on the forum here!
      I have an Ooznest WorkBee with Duet2 WiFi attached.
      Whilst attempting to update my WorkBee firmware, I lost connection to the Duet - subsequently I now can't get WorkBee to run on my browser despite there being a wireless connection confirmed with DCHP address shown on YAT.
      I did do a back up before attempting to update the WorkBee stuff, but don't know how to wind the Duet back to with the back up data.
      Is anyone able to let me know how I can go about this please?
      I've been trawling around so many forums and websites looking for guidance on this and am getting close to being sectioned and spending time in a padded cell, so all or any assistance will be gratefully received.
      Any info needed to assist please ask - as I say, I'm a newbie on here, and to the Duet and WorkBee so am a relative novice.
      Many, many thanks in advance,
      Graham
      oliofundefined droftartsundefined 2 Replies Last reply Reply Quote 0
      • oliofundefined
        oliof @Feathertreecnc
        @Feathertreecnc best to take the SD card out of the duet2 wifi board and check it's contents on a computer. I suspect the /www directory and contents are listing. I seem to remember that Ooznest have their own version of Duet Web Control adjusted for CNC use a bit; maybe contact their support for a set of files?
          droftarts administrators @Feathertreecnc
          @Feathertreecnc Most of the Workbee files, and a support forum specifically for Workbee, is hosted by Ooznest: https://learn.ooznest.co.uk/
          Firmware, configuration files and their version of DWC (Workbee Control) are here: https://learn.ooznest.co.uk/Wiki/WorkBee_Firmware_Releases
          If you can connect via YAT, send M115 and post the response, which will show what firmware version you are on, and you can then choose the appropriate files.
          I've moved this thread to the CNC category.
          • droftartsundefined droftarts moved this topic from Duet Web Control
