    [feature or bug][3.5.0-rc.3] G10 retract z-hop ignores homing
    Beta Firmware
    • timschneiderundefined
      timschneider
      G10 with z-hop configured ignores homing state of z-axis.
      M207 S1.50 R0 F2000 T2000 Z3.5      ; retraction
      Tested on:
      FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.5.0-rc.3+ ELECTRONICS: Duet 3 MB6HC v1.02 or later FIRMWARE_DATE: 2024-02-04 11:40:04
      in SBC Mode.
      Is it a feature or a bug?
      Tim
        dc42 administrators @timschneider
        @timschneider is this a problem, if it still hops by the configured amount? Or have you found that it doesn't?
        timschneiderundefined 1 Reply Last reply Reply Quote 0
          timschneider @dc42
          @dc42 oh yes, it is a problem, I was probing around with an unhomed printer and tried to reproduce an error I had in the last print where I was unable to acknowledge a blocking messages while printing. So I started a jobfile with no movements and only a G4 init to put the printer into paused state. The printbed was at its max and unhomed, when I cancled the print, the printer tried to move the printbed further in the max position with a strong sound. So I started to investigate and put a
          if move.axes[2].homed infront of every z movemend command - but the problem was still there until I stumbled over the G10. after putting a if move.axes[2].homed infront of the G10, the problem was gone.
          I was not sure if it is a feature or bug, but at least it is some sort of inconsistency, as the tool/extruder is not driven when it is not heated up with G10, even if it tries to.
            timschneider @timschneider
            ok, my use pattern was the cause of the "problem"
            The problem occures when you do the following:
            printer is unhomed
            T0 active and Z-Hop configured
            M207 S0.45 R0 F2000 T2000 Z0.5       ; retract for PLA
            content of cancel.g
            G10
            M99
            content of pause.g
            M99
            content of jobfile.g
            T0
            G4 S10
            • start jobfile.g
            • pause printjob via DWC (M24)
            • cancel printjob via DWC (M0)
            • repeat the above steps and the z-axis will accumulate the z-hops, 0.0, 0.5, 1.0, 1.5 ... and so on
            it looks like, cancel is resetting the retration state without undoing the retraction/z-hop if it was retracted and is adding the z-hop to the current z-axis position.
            M115
            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.5.0-rc.3 ELECTRONICS: Duet WiFi 1.02 or later + DueX5v0.11 FIRMWARE_DATE: 2024-01-24 17:56:24
            //Edit
            there is no difference if the printer is homed or not - G10 and cancel will ignore machine limits.
            ok this would explaine another usecase we often use.
            If we have very long printjobs > 1 week, we sometimes use M916 to change the gcode mid print.
            • pause print
            • cancel print
            • change jobfile
            • edit resurrect.g
            • M916
            and sometimes the z-position does not match the current machine position from the printhead (the printhead is a few mm above the printed object)
              @timschneider thanks. Please file an issue at https://github.com/Duet3D/RepRapFirmware/issues.
              I think a related issue is that there will be a problem if the current machine Z height plus the Z hop amount exceeds the Z maximum defined in M208. You could mention this in your issue report too.
