    SZP as Z-Stop calibration help
    • KenDundefined
      KenD
      Can anyone help me with the calibration procedure for using the SZP as a Z-stop? I am having a terrible time with this. I just removed a smart IR probe in favor of the SZP and I have no trouble communicating with it but I am clearly missing something when it comes to calibration.
      KenDundefined 1 Reply Last reply Reply Quote 0
      • KenDundefined
        KenD @KenD
        @KenD ```
        code_text
        ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.3 on Sat Mar 02 2024 14:18:20 GMT-0500 (Eastern Standard Time)
        ;CAN BUS
        G4 S2 ; wait for expansion boards to start
        ; General
        M550 P"Core6" ; set hostname
        ; Accessories
        M575 P1 S0 B57600 ; configure PanelDue support
        M552 P192.168.9.240 S1 ; configure Ethernet adapter
        ;M586 P0 S1             ; configure HTTP
        ; Smart Drivers
        M569 P0.0 S0 D2     ; driver 0.0 goes forwards (X axis)
        M915 P0.0 S10 F0 R0 ; set StallGuard threshold
        M569 P0.1 S1 D2     ; driver 0.1 goes backwards (Y axis)
        M915 P0.1 S10 F0 R0 ; set StallGuard threshold
        M569 P0.2 S0 D2     ; driver 0.2 goes backwards (Z axis)
        M569 P0.3 S1 D2     ; driver 0.3 goes forwards (extruder 0)
        M569 P0.4 S0 D2     ; driver 0.4 goes backwards (Z axis)
        M569 P0.5 S0 D2     ; driver 0.5 goes backwards (Z axis)
        ; Motor Idle Current Reduction
        M906 I50 ; set motor current idle factor
        M84 S60  ; set motor current idle timeout
        ; Axes
        M669 K1                             ; Configure Core XY Kinematics
        M584 X0.0 Y0.1 Z0.2:0.4:0.5         ; set axis mapping
        M671 X330:650:00 Y300:50:50 S2   	  ; Set the Z motor locations and max correction in mm
        M350 X16 Y16 Z16 I1                 ; configure microstepping with interpolation
        M906 X1000 Y1000 Z1000              ; set axis driver currents
        M92 X80 Y80 Z6405                   ; configure steps per mm
        M208 X0:680 Y0:320 Z0:365           ; set minimum and maximum axis limits
        M566 X900 Y900 Z120                 ; set maximum instantaneous speed changes (mm/min)
        M203 X9000 Y9000 Z500               ; set maximum speeds (mm/min)
        M201 X2000 Y2000 Z100               ; set accelerations (mm/s^2)
        ;M201.1 X500 Y500                    ; set Acceleration while homing
        ; Extruders
        M584 E0.3   ; set extruder mapping
        M350 E16 I1 ; configure microstepping with interpolation
        M906 E1000  ; set extruder driver currents
        M92 E830    ; configure steps per mm
        M566 E150   ; set maximum instantaneous speed changes (mm/min)
        M203 E7000  ; set maximum speeds (mm/min)
        M201 E400   ; set accelerations (mm/s^2)
        ; Accelerometer
        M955 P120.0 I64 ; Add accelerometer on SZP with CAN address 120 and specify orientation
        ; Scanning Z probe
        M558 P11 C"120.i2c.ldc1612" F4000 T4000             ; set scanning Z probe as primary z probe and dive height
        M308 A"SZP coil" S10 Y"thermistor" P"120.temp0"     ; thermistor on coil
        M558.2 S20 R146027                                ; set drive current and reading offset
        G31 X24 Y0 Z2.5                                     ; set Z probe Offset and Trigger height
        ; Smart IR Probe
        ;M558 K0 P8 C"io3.in" H5 F200 T6000   ; configure to MODE 8 for IR Z PROBE and Probe this point 3 TIMES. On Duet 3, the IR probe is always in digital mode.
        ;G31 P475 X21 Y0 Z2.23                ; set Z probe trigger value, offset and trigger height
        ;M574 X2 S2 ; configure X axis high end endstop for SZP Accelerometer
        ;M574 Y1 S2 ; configure Y axis low end endstop for SZP Accelerometer
        ;M574 Z1 S2 ; configure Z axis low end endstop for SZP
        M574 X2 S3 ; configure X axis high end endstop for single motor stall
        M574 Y1 S3 ; configure Y axis low end endstop for single motor stall
        M574 Z1 S2 ; configure Z axis low end endstop for Z probe
        ; Mesh Bed Compensation
        M557 X5:320 Y5:670 S25:25 ; define grid for mesh bed compensation
        ; Sensors
        M308 S0 P"temp0" Y"thermistor" A"Heated Bed" T100000 B3950 C7.06e-8     ; configure sensor #0
        M308 S1 P"temp1" Y"thermistor" A"nozzle" T500000 B4723 C1.196220e-7     ; configure sensor #1
        ;M308 S1 P"temp1" Y"pt1000" A"Nozzle"                                   ; configure sensor #1
        ;M308 S2 P"temp2" Y"thermistor" A"ambient" T100000 B3950 C7.06e-8       ; configure sensor #2
        M308 S11 Y"mcu-temp" A"MCU"                 ; defines sensor 10 as MCU temperature sensor
        M308 S12 Y"drivers" A"Duet stepper drivers" ; defines sensor 11 as stepper driver temperature sensor
                                                    ; Case fan - configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
                                                    ; !!! Reports 0C when there is no warning, 100C if any driver reports over-temperature
                                                    ; !!! warning , and 150C if any driver reports over-temperature shutdown
          ; Filament Run-Out Sensor
        M591 D0 P3 C"io8.in" S1 R50:150 L25.47 E3.0  		; Duet3D magnetic sensor(P3) for extruder drive 0(D0), connected to endstop input 3 (C3), tolerance 70 to 130%, 3mm comparison length(E3),
                                                        ; L=Filament movement per complete rotation of the sense wheel, in mm      S0= Disabled
        M950 H0 C"out0" T0                ; create bed heater #0
        M143 H0 P0 T0 C0 S140 A0          ; configure heater monitor #0 for heater #0
        M307 H0 R0.983 K3.090:0.000 D2.12 E1.35 S1.00 B0 ; configure model of heater #0 Bang-Bang mode
        M950 H1 C"out1" T1                ; create nozzle heater #1
        M143 H1 P0 T1 C0 S285 A0          ; configure heater monitor #1 for heater #1
        M307 H1 R2.608 K0.408:0.000 D3.88 E1.35 S1.00 B0 V24 ; configure model of heater #1 PWM Mode
        ; Heated beds
        M140 P0 H0                        ; configure heated bed #0
        M950 F0 C"out3"                        ; create Part fans 24v 2 wire Fan #0
        M106 P0 C"Part" S0 L0 X1 B0.5          ; configure fan #0
        M950 F1 C"out2"                        ; create Tool Fan 24v 2 wire Fan #1
        M106 P1 C"Tool" S0 B0.5 H1 T40         ; configure fan #1
        M950 F2 C"out7"                		   ; create MCU Fan 12v 2 wire. Fan #2
        M106 P2 C"Case" S0 L0 X1 B0.5 T35 H12  ; configure fan #2
        M563 P0 S"Mosquito" D0 H1 F1 ; create tool #0
        M568 P0 R0 S0                ; set initial tool #0 active and standby temperatures to 0C
        T0   ; select first tool
