M116 Hanging after M568 Error
I was able to break out of it by sending an M108 command, but I got an error in the console for an M568 command in this file to set the second layer temps.
The errors:
Error: CAN response timeout: board 20, req type 6013, RID 971 Error: at column 2: Error: CAN response timeout: board 21, req type 6013, RID 969 Error: at column 2: M568: The code from the file at this line:
; stop printing object SECTIONED HULK BBC CARBON FOR MACHINING TEST.STL id:2 copy 0 ;LAYER_CHANGE ;Z:0.6 ;HEIGHT:0.3 ;LAYER:1 G1 E-1 F2400 ;WIPE_START G1 F19200 G1 X256.922 Y240.201 E-1 ;WIPE_END G1 Z.6 F450 M568 P0 S280 ; set temperature M568 P1 S215 ; set temperature M140 S60 ; set bed temperature ; printing object SECTIONED HULK BBC CARBON FOR MACHINING TEST.STL id:2 copy 0 G1 Z1 G1 X297.189 Y413.826 F24000 G1 Z.6 F450 G1 E2 F1800 M122 outputs:
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6XD version 3.5.0-rc.3 (2024-01-24 17:59:29) running on Duet 3 MB6XD v1.01 or later (SBC mode) Board ID: 0JD2M-999AL-D25SW-6JKD0-3S06R-95ZB1 Used output buffers: 12 of 40 (40 max) === RTOS === Static ram: 153600 Dynamic ram: 92880 of which 184 recycled Never used RAM 93072, free system stack 112 words Tasks: SBC(2,ready,23.8%,407) HEAT(3,nWait 6,0.4%,322) Move(4,nWait 6,13.9%,213) CanReceiv(6,nWait 1,44.1%,770) CanSender(5,nWait 7,0.3%,325) CanClock(7,delaying,0.1%,346) MAIN(2,running,17.0%,444) IDLE(0,ready,0.4%,30), total 100.0% Owned mutexes: Telnet(MAIN) === Platform === Last reset 25:02:31 ago, cause: power up Last software reset at 2024-03-07 09:55, reason: User, Gcodes spinning, available RAM 95784, slot 0 Software reset code 0x6003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x04 Aux0 errors 0,1,0 MCU temperature: min 29.4, current 46.7, max 50.4 Supply voltage: min 25.7, current 25.8, max 26.2, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0 Heap OK, handles allocated/used 99/40, heap memory allocated/used/recyclable 4096/2644/1884, gc cycles 11 Events: 0 queued, 0 completed Driver 0: ok Driver 1: ok Driver 2: ok Driver 3: ok Driver 4: ok Driver 5: ok Date/time: 2024-03-20 11:35:37 Slowest loop: 1226.17ms; fastest: 0.04ms === Storage === Free file entries: 20 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 56, maxWait 51691952ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 33337, on retry 20333, too short 109285, wrong shape 349661, maybepossible 18667 === DDARing 0 === Scheduled moves 7070, completed 7070, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 17], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.2 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP* is doing "M25" in state(s) 0 Telnet* is doing "M122" in state(s) 0 File* is doing "M116 P"{state.currentTool}"" in state(s) 0 0 19, running macro USB is idle in state(s) 0 Aux is doing "M25" in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC* is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2* is doing "M116 P1 S5" in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x80000003 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 0 clear 0 Extruder 0: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0 Extruder 1: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0 === CAN === Messages queued 1547554, received 122035323, lost 0, errs 1, boc 0 Longest wait 3ms for reply type 6013, peak Tx sync delay 765, free buffers 50 (min 47), ts 450758/450757/0 Tx timeouts 0,0,0,3,0,0 last cancelled message type 6013 dest 21 === SBC interface === Transfer state: 5, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 41823/41823 SPI underruns 0, overruns 0 State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2600c Buffer RX/TX: 2220/3712-0, open files: 0 === Duet Control Server === Duet Control Server version 3.5.0-rc.3 (2024-01-26 12:34:19) File /opt/dsf/sd/gcodes/Jarvie/Sectioned Hulk Modifier Test_0.6n_NYLON_22h34m.gcode is selected, processing HTTP: Buffered code: M25 Buffered code: M568 P0 A1 Buffered code: M568 P1 A0 Buffered codes: 104 bytes total File: Buffered code: M116 P{state.currentTool} ; wait for tool 0 heaters to reach operating temperature Buffered codes: 52 bytes total > Suspended code: M116 P0 S5 > Suspended code: M572 D0 S0.006 > Suspended code: ; printing object SECTIONED HULK BBC CARBON FOR MACHINING TEST.STL id:2 copy 0 > Suspended code: G1 X389.242 Y468.798 F24000 > Suspended code: G1 Z.6 F450 > Suspended code: G1 E2 F1800 > Suspended code: M204 P1000 > Suspended code: G1 F4800 > Suspended code: G1 X332.27 Y468.798 E3.95326 > Suspended code: G1 X332.27 Y171.202 E20.65005 > Suspended code: G1 X389.242 Y171.202 E3.95326 > Suspended code: G1 X389.242 Y199.689 E1.9767 > Suspended code: G1 X389.242 Y468.708 E18.6671 > Suspended code: M204 P4000 > Suspended code: G1 X389.242 Y468.708 F24000 > Suspended code: M73 P2 R1314 > Suspended code: G1 X389.828 Y469.383 > Suspended code: M204 P1000 > Suspended code: G1 F4800 > Suspended code: G1 X331.684 Y469.383 E4.03459 > Suspended code: G1 X331.684 Y170.617 E20.73124 > Suspended code: G1 X389.828 Y170.617 E4.03459 > Suspended code: G1 X389.828 Y199.689 E2.01729 > Suspended code: G1 X389.828 Y469.293 E18.7077 > Suspended code: M204 P4000 > Suspended code: G1 X389.828 Y469.293 F24000 > Suspended code: G1 X390.414 Y469.969 > Suspended code: M204 P1000 >> Doing macro tpost0.g, started by T0 >>> Doing macro 0:/sys/System Macros/Tool Change/tpost.g, started by M98 P{"0:/sys"^"/System Macros/Tool Change/tpost.g"} >>> Number of flush requests: 1 File2: Buffered code: M116 P1 S5 Buffered code: M572 D1 S0.04 Buffered code: ; printing object SECTIONED HULK BBC CARBON FOR MACHINING TEST.STL id:2 copy 0 Buffered code: G1 X274.174 Y310.448 F24000 Buffered code: G1 Z63.3 F450 Buffered code: G1 E2 F1800 Buffered code: G1 F4800 Buffered code: G1 X274.623 Y311.463 E.06673 Buffered code: G1 X275.389 Y312.452 E.07521 Buffered code: G1 X276.265 Y313.197 E.06914 Buffered code: G1 X276.876 Y313.561 E.04276 Buffered code: G1 X277.353 Y313.744 E.03072 Buffered code: G1 X275.617 Y316.744 E.2084 Buffered code: G1 X271.225 Y316.744 E.26407 Buffered code: G1 X269.493 Y313.744 E.20828 Buffered code: G1 X269.225 Y313.744 E.01611 Buffered code: G1 X269.227 Y313.208 E.03223 Buffered code: G1 X269.493 Y313.208 E.01599 Buffered code: G1 X271.225 Y310.208 E.20828 Buffered code: G1 X274.055 Y310.208 E.17015 Buffered code: G1 X273.852 Y309.672 E.03446 Buffered code: G1 X271.225 Y309.672 E.15795 Buffered code: G1 X269.493 Y306.672 E.20828 Buffered code: G1 X269.26 Y306.672 E.01401 Buffered code: G1 X269.263 Y306.137 E.03217 Buffered code: G1 X269.493 Y306.137 E.01383 Buffered code: G1 X271.225 Y303.137 E.20828 Buffered code: G1 X274.923 Y303.137 E.22234 Buffered code: G1 X274.135 Y304.532 E.09633 Buffered codes: 1404 bytes total Code buffer space: 2220 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 7 Full transfers per second: 42.11, max time between full transfers: 121.4ms, max pin wait times: 74.9ms/23.6ms Codes per second: 28.78 Maximum length of RX/TX data transfers: 5128/3328 M122 B20 Diagnostics for board 20: Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.3 (2024-01-24 17:55:14) Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25) All averaging filters OK Never used RAM 1544, free system stack 55 words Tasks: Move(3,nWait 7,3.0%,79) HEAT(2,nWait 6,4.8%,91) CanAsync(5,nWait 4,0.0%,49) CanRecv(3,nWait 1,1.8%,65) CanClock(5,nWait 1,0.4%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,delaying,66.4%,53) MAIN(1,running,34.2%,315) IDLE(0,ready,19.3%,27) AIN(2,delaying,90.5%,112), total 220.5% Owned mutexes: Last reset 25:10:52 ago, cause: power up Last software reset data not available Driver 0: pos 0, 404.7 steps/mm, standstill, SG min 0, read errors 14, write errors 0, ifcnt 35, reads 59693, writes 35, timeouts 31, DMA errors 0, CC errors 0, failedOp 0x71, steps req 0 done 53253485 Moves scheduled 605288, completed 605288, in progress 0, hiccups 1669, segs 57, step errors 0, maxLate 2 maxPrep 562, maxOverdue 164274, maxInc 132515, mcErrs 0, gcmErrs 0, ebfmin -1.00 max 1.00 Peak sync jitter -1/15, peak Rx sync delay 260, resyncs 0/0, no timer interrupt scheduled VIN voltage: min 22.9, current 26.0, max 45.4 MCU temperature: min 23.9C, current 69.5C, max 98.7C Last sensors broadcast 0x00006002 found 3 86 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 115277228, send timeouts 0, received 2151698, lost 0, errs 1, boc 0, free buffers 18, min 17, error reg 20000 dup 0, oos 36/0/0/18, bm 0, wbm 0, rxMotionDelay 380, adv -164096/108406 Accelerometer: LIS3DH, status: 00 I2C bus errors 0, naks 3, contentions 0, other errors 0 === Filament sensors === Interrupt 4 to 134us, poll 8 to 2564us Driver 0: pos 2196.91, errs: frame 308 parity 0 ovrun 0 pol 0 ovdue 0 M122 B21 Diagnostics for board 21: Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.3 (2024-01-24 17:55:14) Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25) All averaging filters OK Never used RAM 2192, free system stack 55 words Tasks: Move(3,nWait 7,0.1%,79) HEAT(2,nWait 6,3.7%,91) CanAsync(5,nWait 4,0.0%,49) CanRecv(3,nWait 1,1.0%,71) CanClock(5,nWait 1,0.4%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,delaying,65.6%,53) MAIN(1,running,41.8%,315) IDLE(0,ready,19.0%,27) AIN(2,delaying,88.9%,112), total 220.5% Owned mutexes: Last reset 25:10:53 ago, cause: power up Last software reset at 2024-02-01 11:32, reason: HardFault, available RAM 2016, slot 0 Software reset code 0x0060 ICSR 0x00000003 SP 0x20002f08 Task MAIN Freestk 813 ok Stack: 200048c8 00000000 00000001 4aa36799 00000000 0000f3cb 4aa36798 21000000 20001488 0000f00d a5a5a5a5 0080bdc1 00000089 000001f4 20001ce0 0001285f 00000000 00000000 20004370 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 Driver 0: pos 0, 404.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 16, reads 40538, writes 16, timeouts 8, DMA errors 0, CC errors 0, failedOp 0x41, steps req 0 done 1013751 Moves scheduled 4732, completed 4732, in progress 0, hiccups 8, segs 31, step errors 0, maxLate 1 maxPrep 396, maxOverdue 3553, maxInc 2672, mcErrs 0, gcmErrs 0, ebfmin -0.93 max 1.00 Peak sync jitter -1/7, peak Rx sync delay 243, resyncs 0/0, no timer interrupt scheduled VIN voltage: min 24.9, current 26.5, max 26.8 MCU temperature: min 27.9C, current 75.6C, max 81.4C Last sensors broadcast 0x00018004 found 3 32 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 7715520, send timeouts 0, received 1546216, lost 0, errs 1, boc 0, free buffers 18, min 17, error reg 20000 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 352, adv 35330/100443 Accelerometer: LIS3DH, status: 00 I2C bus errors 0, naks 3, contentions 0, other errors 0 === Filament sensors === Interrupt 4 to 85us, poll 6 to 1313us Driver 0: pos 13983.05, errs: frame 21 parity 0 ovrun 0 pol 0 ovdue 0 -
@curieos please try the latest 3.5 firmware build from https://www.dropbox.com/scl/fo/yzchzlyxmxlzywjawqflu/h?rlkey=tl7dfs75yozhfgpze0jnkn32n&dl=0.
@dc42 This is in SBC mode, can I just upload these to the FW directory and send the update commands?
@dc42 Is there a DSF or DWC release to go with those? I just encountered some very strange behavior retrying that print with those binaries.
I first homed the machine before the print. Then I started the print, and it homed again (as expected), and then immediately it rehomed. It then moved to the "starting position" near the nozzle wiper, skipped over waiting for the tool to heat and wiping in the tool change macros, moved to the print start location, waited for T0 to heat up, and started printing. It then got halfway done with the skirt, retracted, and moved back to the wiping location, then moved back to where it stopped with the skirt, did the extruder priming sequence, and resumed the skirt. I then paused it, and it moved to the park position. I tried resuming, and it then properly ran the toolchange sequence, but then it went to the start of the brim and seemingly randomly extruded a few lines in varying directions, unrelated the print geometry.
The start gcode for this file is:
; Run nozzle diameter and filament check M98 P"0:/sys/System Macros/Config Checks/nozzle_check.g" L0.6 S0.6 M98 P"0:/sys/System Macros/Config Checks/filament_check.g" L"NYLON" S"PVA" ; set extruder temp M568 P0 S275 R170 A1 M568 P1 S210 R120 A1 ; Set and wait for bed temp M190 S80 ; Home all axes G28 ; Enable mesh compensation M98 P"0:/sys/System Macros/Config Checks/load_heightmap.g" ; Move to starting position G0 H2 X{move.axes[0].min} Y50 F6000 ; Select first tool T0 ; Move near start G1 X251.37 Y156.171 Z2.3 F12000 G21 ; set units to millimeters G90 ; use absolute coordinates M83 ; use relative distances for extrusion T0 M116 P0 S5 ; Filament gcode M572 D0 S0.006 M107 ;LAYER_CHANGE ;Z:0.3 ;HEIGHT:0.3 The macros called can be found here:
https://github.com/HartSmart-Products/HSP1-I-SD-Image/tree/mainedit: Attached is the version report for all duet components
@curieos said in M116 Hanging after M568 Error:
As you have already installed 3.5.0-rc3 from the package server, yes you can. However, to get the full fix you will need a DSF update too. We expect to release rc4 very soon.
