DIY gantry milling machine
I plan to spend very little money to DIY a gantry milling machine. Do you have any good suggestions on accessories selection?
Has anyone used this kit? https://www.oyostepper.de/goods-898-S-Serie-3-Achsen-CNC-Fräser-Kit-30-Nm-Nema-23-Schrittmotor-und-Schritttreiber.html
Is the quality guaranteed? -
@alex22 The Duet6HC can drive these steppers directly and AFAIK at a higher voltage than 36V. Their external drivers and the 36V PSU are obsolete in that case.
The steppers have a 10mm shaft, which have to match your application. (pulleys or ballscrews)
