    Kobra2Max accelerometer wiring, possible?
    1
    79
    • bug2k22undefined
      bug2k22
      I have all the other hardware on this printer working with the Duet3 6HC, is it possible to wire up this accelerometer to the duet? The duet docs show that an interrupt signal is required in addition to the pins shown. The device appears to use the LIS2DW12. There are 2 accelerometers on this printer, one integrated onto the pcb within the print head and another (this one) on the print bed as it's a 'bed slinger' type. I realise it's unlikely both can be used at the same time, but is it possible to use either individually?
      Thanks.
      [Edit]
      I've got the accelerometer on the print head working, there was no wire for the interrupt pin but I did find a solder pad labelled TP1 which seemed to be connected the correct pin on the LIS2DW12 package. This works fine, but only for the x and z axis as this is a 'bed slinger'. There does not seem to be any such track or connection to the interrupt pin on the LIS2DW12 package on the print bed accelerometer to measure the y axis.
      This is no big deal as it's a simple process to swap this out for the duet accelerometer for the bed.
