    Pause/resume issues in 3.5.0rc3+5?
    Beta Firmware
    687
    • Exerqtorundefined
      Exerqtor @dc42
      @dc42 Okok, I'll pull them, try one least time and report back before hitting the bunk.
      A little bit off topic, but: I don't know if this is expected behaviour or (or when it got introduced), but for some reason this command:
      M291 S4 R"Bed tramming" P"Are you sure you want to tram the bed?" K{"YES","CANCEL",}
      Don't end up posting a message on PD, just DWC.
      And I can confirm that the resume now works again, and that the Z-issues is resolved. I didn't notice any delay between between restoring the XYZ position and starting printing again though, at least not more than it's "allways" been.
      • Exerqtorundefined Exerqtor has marked this topic as solved
        dc42 administrators @Exerqtor
        @Exerqtor which version of PanelDueFirmware are you using?
        Exerqtorundefined 1 Reply Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @dc42
          @dc42 Uuhm i'm quite sure it's 3.5.0-rc8 / the latest one avalible on github.
          I'll check once i get home.
            @Exerqtor it works for me if I run that command from the DWC console, using the latest firmware build and PanaDueFirmware 3.5.0-rc6. I'll re-test using -rc8.
            Edit: and using -rc8 it displays on both too. Does that box display on both DWC and PD when you run it from the DWC console?
            • Exerqtorundefined
              Exerqtor @dc42
              @dc42 Ok, then i bet i've forgot to install rc8 or something, I'll have a look later!
              Didn't try the command in DWC console, but the if i trued running the bed leveling from PD (that command is part of bed.g) nothing popped up on PD, so i went to check in DWC an there it was displayed.
              Edit:
              Just got home and checked PD, it's got 3.5.0-rc8 installed like I thought. And i just tried to run a tram from the button on PD, now it displayed the message like it should. So idk what was going on yesterday tbh.
