    Please explain this..
    • Loffy770
      Loffy770 last edited by
      I have upgraded from 1.17 to 1.20 on my D-WiFi.
      Im not getting Z to move to the probe point I want, it homes Z at X0 Y0 no matter what I set in homez or homeall..
      It must be reading the home point from somewhare but I cant find it…
      It mowes to this point G1 X100 Y100 F2000 and then move back and G30 runs at X0 Y0 (Please see the below for the context in homez of this move)
      Does anyone have a clue? If you do please explain what Im doing wrong..
      Below are the exact values I have
      Config.g
      M558 P1 X0 Y0 Z1 H3 F200 T5000 R0 ; smart IR Z probe, used for homing Z axis only, dive height 3mm, probe speed 200mm/min, travel speed 5000mm/min, no recovery time
      G31 P500 X0.0 Y-15.0 Z1.2 ; set threshold and offsets Z sets the hight of nozzle from table , negative value goes up.
      M557 X30:360 Y30:260 S68 ; Define mesh grid
      Homez.g
      G91 ; relative mode
      G1 Z4 F200 ; raise head 4mm to ensure it is above the Z probe trigger height
      G90 ; back to absolute mode
      G1 X100 Y100 F2000 ; put head over the centre of the bed, or wherever you want to probe
      G30 ; lower head, stop when probe triggered and set Z to trigger height
      • SuperJETT
        SuperJETT last edited by
        I have a similar setup but with piezo sensor.
        Have you tried running those individual codes through console manually in the same order as your homez?
        Custom CoreXY at home with Duet Wifi, Hemera
        • Loffy770
          Good Idea, I just did it and its when I execute G30 that it does its own stuff…
          When G30 is executed it moves X and Y back to zero before probing.
          Probing works but I cant controll it.
          • DjDemonD
            DjDemonD last edited by
            Make sure you delete deploy probe and stow probe macros from sys folder. These were new in 1.19 I think and are enabled if present.
            www.precisionpiezo.co.uk
            • Loffy770
              Thank you that was it 🙂
