    Precision Piezo on a Toolchanger with a Roto Board
    Third-party add-ons
    • S1lencerundefined
      S1lencer
      I am a little bit lost at the moment.
      I have a universal precision piezo Board mounted on the Head of an e3d-Style Toolchanger.
      The complete Toolchangehead (Stepper, Z-endstop = Precision-Piezo on Pin io0.in , and y-Endstop on Pin io1.in) is controlled over a roto Toolboard with CAN Address 24.
      My Problem lies now in the two "Z-Probes".
      First off, I would like to use the Precision-Piezo in digital mode on Pin io0.in. At the moment the Cables are connected as follows, ground -> io0.ground, V+ -> io0.+5v, and signal -> io0.in
      fo the Code in the config I added the following line:
      M558 K0 P1 R1.0 C"!24.io0.in" H7 F500 T10000                                     ; set Z probe type to effector and the dive height + speeds
      G31 K0 P500 X0 Y0 Z0                                                             ; set Z probe trigger value, offset and trigger height
      For the Scanning Z-Probe on the Roto Toolboard, i have the following added to the Config:
      ; Scanning Z probe
      M558 K1 P11 C"24.i2c.ldc1612" F36000 T36000          ; configure SZP as probe 1, type 11, on CAN address 120
      M308 A"SZP coil" S10 Y"thermistor" P"24.temp0"       ; thermistor on coil
      G31 K1 Z2 Y-10                                       ; define probe 1 offsets and trigger height
      M558.2 K1 S15 R101133                                ; set drive current and reading offset
      M557 X10:590 Y10:590 S10                           ; Define mesh grid for probe 1 (overwrites probe 0 mesh grid)
      My Questions now are how can i test if everything works correctly? I have at the moment the problem that my Precision-Piezo boart triggers correctly but where can i see if the signal goes through to the duet itself? The same goes for the Moment for the Y-endstop on pin io1.in + io1.+3,3v (simple Omron switch).
      Is there anywhere a dashboard, where I can see if the Signals will be picked up correctly by the duet?
      Fo Example, on my CNC-Mill software i have an simplified IO-Signal overview of all the inputs witch a light witch goes on when triggered.
      Greetings an thanks for the Help.
      • S1lencerundefined S1lencer marked this topic as a question
        dc42 administrators @S1lencer
        @S1lencer said in Precision Piezo on a Toolchanger with a Roto Board:
        Use P8 in that command, not P1. P1 means analog mode which is not supported on tool boards.
        The status of Z probes is displayed in DWC.
        S1lencerundefined 1 Reply Last reply Reply Quote 0
        • S1lencerundefined
          S1lencer @dc42
          Hi, that did the Trick.
          Thanks fo the wise answer.
          • S1lencerundefined S1lencer has marked this topic as solved
