    Long standing macro not working Only on 3.5rc4 and Mini5+
    Beta Firmware
    • Nurgelrotundefined
      Nurgelrot
      Hello, The print_area_mesh.g macro that many people have been using for a while now errors out on the Mini5+ under 3.5-rc4. with the following: (I cancelled the print.)
      4/15/2024, 12:39:53 PM	Cancelled printing file 0:/gcodes/testring.gcode, print time was 0h 10m
      4/15/2024, 12:39:41 PM	M25
      Printing paused at X225.0 Y225.0 Z4.1
      4/15/2024, 12:39:38 PM	Resume state saved
      4/15/2024, 12:39:38 PM	Error: in file print_area_mesh.g line 58: unknown variable 'var.meshY'
      4/15/2024, 12:39:38 PM	Error: in file print_area_mesh.g line 57: unknown variable 'var.meshX'
      4/15/2024, 12:39:38 PM	Error: in file print_area_mesh.g line 44: in file macro line 0: Expression nesting too deep
      4/15/2024, 12:39:38 PM	Error: in file print_area_mesh.g line 43: in file macro line 0: Expression nesting too deep
      4/15/2024, 12:39:38 PM	Error: in file macro line 59: M557: unknown variable 'meshX'
      4/15/2024, 12:39:38 PM	81 points probed, min error 0.010, max error 0.123, mean 0.063, deviation 0.026
      Height map saved to file 0:/sys/heightmap.csv
      4/15/2024, 12:31:23 PM	Error: in file macro line 50: M557: unknown variable 'meshX'
      4/15/2024, 12:31:23 PM	Set probe grid to use X-min: 53.32040; X-max: 196.6800; Y-min: 53.32040; Y-max: 196.6800
      Exact same g-code sent to a mini5+ running 3.4.6 works as expected. ALSO works as expected when sent to a Super8pro Running the TeamGloomy STM32 port of RRF 3.5-4rc4. Is there some memory/other restriction im unaware of with the Mini5+?
      macro run with M98 P"print_area_mesh.g" A{first_layer_print_min[0]} B{first_layer_print_max[0]} C{first_layer_print_min[1]} D{first_layer_print_max[1]} in prusa slicer 2.7.4 start gcode
      ; This command will only create a mesh of the print area
      ; This will reduce the printing time considerably by only probing what is needed
      var deviationFromOriginal = 20
      var probeGridMinX = move.compensation.probeGrid.mins[0]
      var probeGridMaxX = move.compensation.probeGrid.maxs[0]
      var probeGridMinY = move.compensation.probeGrid.mins[1]
      var probeGridMaxY = move.compensation.probeGrid.maxs[1]
      var pamMinX = {var.probeGridMinX}	; Default the pamMinX value to the min x that is set for the mesh in M557. Originally coming from sys/printer_size_config.g
      var pamMaxX = {var.probeGridMaxX} 	; Default the pamMaxX value to the min x that is set for the mesh in M557. Originally coming from sys/printer_size_config.g
      var pamMinY = {var.probeGridMinY}	; Default the pamMinY value to the min x that is set for the mesh in M557. Originally coming from sys/printer_size_config.g
      var pamMaxY = {var.probeGridMaxY}	; Default the pamMaxY value to the min x that is set for the mesh in M557. Originally coming from sys/printer_size_config.g
      var meshSpacing = {move.compensation.probeGrid.spacings[0]}	; Grabbing the spacing of the current M557 settings
      var minMeshPoints = 3				; The minimal amount of probing points for both X & Y.
      var maxMeshPoints = 10				; The max amount of probing points for both X & Y
      if exists(param.A)
      	set var.pamMinX = {param.A}		; The min X position of the print job
      if exists(param.B)
      	set var.pamMaxX = {param.B}		; The max X position of the print job
      if exists(param.C)
      	set var.pamMinY = {param.C}		; The min Y position of the print job
      if exists(param.D)
      	set var.pamMaxY = {param.D}		; The max Y position of the print job
      if (var.probeGridMinX + var.deviationFromOriginal) >= var.pamMinX	; Check if the difference between the min X and the print job min X is smaller than the set deviation
      	set var.pamMinX = {var.probeGridMinX}								; The difference is smaller than the set deviation so set minX to the minimal of the printer's X
      if (var.probeGridMaxX - var.deviationFromOriginal) <= var.pamMaxX	; Check if the difference between the max X and the print job max X is smaller than the set devation
      	set var.pamMaxX = {var.probeGridMaxX}								; The difference is smaller than the set devation so set maxX to the max of the printer's X
      if (var.probeGridMinY + var.deviationFromOriginal) >= var.pamMinY	; Check if the difference between the min Y and the print job min Y is smaller than the set devation
      	set var.pamMinY = {var.probeGridMinY}									; the difference is smaller than the set devation so set minY to the minimal of the printer's Y
      if (var.probeGridMaxY - var.deviationFromOriginal) <= var.pamMaxY	; Check if the difference between the max X and the print job max X is smaller than the set devation
      	set var.pamMaxY = {var.probeGridMaxY}									; The difference is smaller than the set devation so set maxY to the max of the printer's Y
      var meshX = floor(min(var.maxMeshPoints - 1, (max(var.minMeshPoints - 1, (var.pamMaxX - var.pamMinX) / var.meshSpacing) + 1)))	; Get the number of probes for X taking minMeshPoints and maxMeshPoints into account
      var meshY = floor(min(var.maxMeshPoints - 1, (max(var.minMeshPoints - 1, (var.pamMaxY - var.pamMinY) / var.meshSpacing) + 1)))	; Get the number of probes for Y taking minMeshPoints and maxMeshPoints into account
      var consoleMessage = "Set probe grid to use X-min: " ^ var.pamMinX ^ "; X-max: " ^ var.pamMaxX ^ "; Y-min: " ^ var.pamMinY ^ "; Y-max: " ^ var.pamMaxY "; Probing points: " ^ var.meshX ^ ";" ^ var.meshY	; Set the console message
      M118 P2 S{var.consoleMessage} ; send used probe grid to paneldue
      M118 P3 S{var.consoleMessage} ; send average to DWC console
      M557 X{var.pamMinX, var.pamMaxX} Y{var.pamMinY, var.pamMaxY} P{var.meshX, var.meshY}	; Set the probing mesh
      G0 X{var.pamMinX + ((var.pamMaxX - var.pamMinX)/2) - sensors.probes[0].offsets[0]} Y{var.pamMinY + ((var.pamMaxY - var.pamMinY)/2) - sensors.probes[0].offsets[1]} 	; Move to the center of the print area
      G30	; Set the z height for the center of the print area
      G29	; Probe the print area
      ; Restore the probing mesh to the original settings
      set var.meshX = floor((var.probeGridMaxX - var.probeGridMinX) / var.meshSpacing + 1)
      set var.meshY = floor((var.probeGridMaxY - var.probeGridMinY) / var.meshSpacing + 1)
      M557 X{var.probeGridMinX, var.probeGridMaxX} Y{var.probeGridMinY, var.probeGridMaxY} P{var.meshX, var.meshY}
      Nurgelrotundefined 1 Reply Last reply Reply Quote 0
        Nurgelrot @Nurgelrot
        @Nurgelrot UPDATE @gloomyandy helped me identify someplaces where the macro could make better use of available stack space by loading some local varables with some expression results rather than parsing it all in one go. Fixed the problem. He specualated that in the Mini5+ and even some of the STM32F4xx boards that stack space was already pretty low in 3.4.6 and 3.5 pushed it over for this particular use case. Something for people to keep an eye on.
        dc42undefined 1 Reply Last reply Reply Quote 1
          dc42 administrators @Nurgelrot
          @Nurgelrot you may find your original macros work with the forthcoming 3.5.0 stable release, because I identified and fixed an instance where the expression parser was allocating excessive stack space in some instances, which reduced the maximum expression depth supported.
          Nurgelrotundefined 1 Reply Last reply Reply Quote 1
          • droftartsundefined droftarts referenced this topic
            Nurgelrot @dc42
            @dc42 just a follow upletting you and anyone following this issue that in my case the expression nesting was still too deep even under 3.5.1. I corrected it by making my macro a little cleaner. Basically not loading so much into one variable assignment. but spreading out the math 🙂
