    Multiple keep-out zones (M599)
    Firmware wishlist
    • NeoDueundefined
      NeoDue
      While digging through the change log of RRF 3.5.1, I found the new M599 command. That one would be a great way to avoid collisions with bed clamps (yes, I like my glass print bed...).
      Would it be possible to enhance M599 as follows?
      • support more than one keepout zone (in my case, it would be two, but I guess other users might need up to four zones). The command seems to be prepared for that since it already includes a keepout zone number.
      • add a z coordinate range where the defined keepput zone applies (e.g. from z=0 ... z=1 mm)
      dc42undefined droftartsundefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @NeoDue
        @NeoDue multiple keepout zones is something I had in mind when I wrote the code, so it would be quite easy to implement. Please check whether this has already be raised as a feature request at https://github.com/Duet3D/RepRapFirmware/issues and add it if not.
        You can already include a Z coordinate range when defining a keepout zone.
        NeoDueundefined 2 Replies Last reply Reply Quote 0
          droftarts administrators @NeoDue
          @NeoDue see also https://docs.duet3d.com/User_manual/Reference/Gcodes#m599-define-keepout-zone
          • NeoDueundefined
            NeoDue @dc42
            @dc42 @droftarts thanks a lot! I had focused too much onto the example code.Then I will check Github later today!
              @NeoDue I did an example diagram of M599 for a talk @dc42 did last year. I could probably share that.
              NeoDueundefined 1 Reply Last reply Reply Quote 0
              • NeoDueundefined
                NeoDue @droftarts
                @droftarts Depends on what the diagram shows... if I were to present this feature somewhere, I would probably go for a three-dimensional representation of where the keep-out zones are in the axis coordinate system... correct?
                That might be indeed quite some help for any people who are not used to imagine three-dimensional objects in a room. I would suggest to add such a picture or a link to it to the gcode dictionary.
                • NeoDueundefined
                  NeoDue @dc42
                  @dc42 Issue is created: https://github.com/Duet3D/RepRapFirmware/issues/979
                  One offtopic question, if I may: from your standpoint, is there anything I might add/contribute to clarify or increase understandability of https://github.com/Duet3D/RepRapFirmware/issues/915? I just want to make sure that the feature request contains everything that might be of help in case it might be chosen for implementation some time in the future.
                  When I had created that one, I had several other issues to fight with, therefore I admit I do not consider that data I presented there to be really optimal.
                  Braintoe created this issue in Duet3D/RepRapFirmware
                  open [FeatureRequest]: allow more than one keep-out zone #979
                  open [FeatureRequest]: Add "suppress message" G30 probe option #915
