    3.5.1 "forgetting" the assigned WiFi connection
    Beta Firmware
    344
    • Mr.Crispinundefined
      Mr.Crispin
      I updated to 3,5,1 on one of my Duet-2 (1.04) boards yesterday, and I am encountered an issue where after the update in that I couldn't reconnect to DWC via Wi-Fi
      I connected via a USB cable, and instantly I started receiving Wi-Fi connection errors stating no known networks were available
      I disabled the Wi-Fi Adapter to suppress the error, then re-initialized it, putting it into an idle state.
      Sending M587 shows no networks were saved,
      I then Re-Added my Wi-Fi connection and got re-connected via DWC (the printer prints normally on the new firmware after I got connected) I initially just put it down to the update not doing its thing properly.
      Went to connect to the printer this morning and couldn't, connecting via USB started the cycle i encountered during the upgrade, if I carried out the rectification procedure again I could connect until I shut down then the cycle begins again.
      If I roll back to earlier firmware (on the same board with no changes to the config.g) the problem disappears.
        Can you share an M122 report?
        What is the reported wifi server version?
        The wifi module forgetting the networks after the initial upgrade isn't totally unheard of, but it shouldn't be forgetting it every reboot.
        Mr.Crispinundefined 1 Reply Last reply Reply Quote 0
          Mr.Crispin @Phaedrux
          @Phaedrux said in 3.5.1 "forgetting" the assigned WiFi connection:
          I have permanently rolled back to Release 3.5.0-rc.4
          WiFi Sever is 2.1 Beta 8
          Results of M122 (board ID & MAC Address removed)
          (Edit) I did remove all saved networks using M588 S"*" before re-adding my SSID/Password
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.1 (2024-04-19 14:40:46) running on Duet WiFi 1.0 or 1.01
          Board ID: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
          Used output buffers: 14 of 26 (14 max)
          Static ram: 23256
          Dynamic ram: 72848 of which 12 recycled
          Never used RAM 17028, free system stack 170 words
          Tasks: NETWORK(2,nWait 6,13.1%,220) HEAT(3,nWait 5,0.1%,328) Move(4,nWait 5,0.0%,359) MAIN(1,running,86.2%,745) IDLE(0,ready,0.7%,29), total 100.0%
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:02:31 ago, cause: power up
          Last software reset at 2024-04-20 16:29, reason: User, Gcodes spinning, available RAM 12972, slot 2
          Error status: 0x00
          MCU temperature: min 34.8, current 37.6, max 38.7
          Supply voltage: min 24.1, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min n/a
          Driver 1: standstill, SG min n/a
          Driver 2: standstill, SG min n/a
          Driver 3: standstill, SG min n/a
          Driver 4: standstill, SG min n/a
          Driver 5:
          Driver 6:
          Driver 7:
          Driver 8:
          Driver 9:
          Driver 10:
          Driver 11:
          Date/time: 2024-04-21 11:53:07
          Slowest loop: 11.05ms; fastest: 0.18ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 4.8ms, write time 0.0ms, max retries 0
          DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
          no step interrupt scheduled
          Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
          === DDARing 0 ===
          Heater 1 is on, I-accum = 0.0
          Movement locks held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Q0 segments left 0
          Code queue 0 is empty
          === Network ===
          Slowest loop: 8.32ms; fastest: 0.00ms
          Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
          HTTP sessions: 1 of 8
          === WiFi ===
          Interface state: active
          Firmware version 2.1beta8
          MAC address xxxxxxxxxxxxxxxx
          Module reset reason: Turned on by main processor, Vcc 3.39, flash size 4194304, free heap 39236
          WiFi IP address 192.168.88.222
          Signal strength -55dBm, channel 6, mode 802.11n, reconnections 0
          Clock register 00002002
          Phaedruxundefined 2 Replies Last reply Reply Quote 0
            Phaedrux Moderator @Mr.Crispin
            @Mr-Crispin said in 3.5.1 "forgetting" the assigned WiFi connection:
            And the problem doesn't occur there anymore?
              Correct, As soon as I roll back the firmware, the problem disappears
                It looks like the wifi firmware wasn't actually updated? Or the M122 was collected after reverting?
                Can you try updating using the full release zip file and confirming that the wifi server firmware is actually getting updated to the full non-beta release?
                https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.1
                  @Phaedrux
                  That's the package I originally downloaded.
                  It's working fine on the older firmware, so I will leave well alone until i have to update
                    If it's a bug we can reproduce we can try to fix it.
                    • Phaedruxundefined Phaedrux moved this topic from Firmware installation
                    • Mr.Crispinundefined Mr.Crispin referenced this topic
