    FTP: WiFi reported error: Listen failed
    1081
    • resam
      resam last edited by
      I upgraded to v1.20 for RRF and WifiServer.
      When I'm trying to copy multiple files via FTP the Wifi seems to stop working and the FTP connection no longer works:
      [c]WiFi reported error: Listen failed[/c]
      M122 before testing:
      M122
      Used output buffers: 3 of 32 (6 max)
      RepRapFirmware for Duet WiFi version 1.20 running on Duet WiFi 1.0
      Board ID: 08DDM-9FAM2-LW4S4-6J9FL-XXXXX-XXXXX
      Static ram used: 15448
      Dynamic ram used: 99144
      Recycled dynamic ram: 96
      Stack ram used: 1392 current, 4480 maximum
      Never used ram: 11904
      Last reset 00:00:52 ago, cause: software
      Last software reset at 2017-12-29 11:45, reason: User, spinning module GCodes, available RAM 11880 bytes (slot 2)
      Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
      Error status: 0
      Free file entries: 9
      SD card longest block write time: 2.1ms
      MCU temperature: min 27.2, current 27.7, max 28.0
      Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0
      Date/time: 2017-12-29 11:46:44
      Cache data hit count 180937635
      Slowest main loop (seconds): 0.035305; fastest: 0.000042
      MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 0, completed moves: 0
      Bed compensation in use: none
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      Network state is running
      WiFi firmware version 1.20
      WiFi MAC address 5c:cf:7f:a4:a5:aa
      WiFi Vcc 3.35, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 13640
      WiFi IP address 10.0.0.42
      WiFi signal strength -38dBm, reconnections 0, sleep mode modem
      HTTP sessions: 1 of 8
      Socket states: 2 0 0 0 0 0 0 0
      Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      DWC stay connected and I can get a M122 output afterwards:
      M122
      Used output buffers: 3 of 32 (14 max)
      Last reset 00:01:54 ago, cause: software
      Error status: 0
      MCU temperature: min 27.4, current 27.8, max 27.9
      Date/time: 2017-12-29 11:47:46
      Cache data hit count 424207632
      Slowest main loop (seconds): 0.156113; fastest: 0.000080
      Segments left: 0
      WiFi flash size 4194304, free heap 13568
      Event logging to SD card says:
      2017-12-29 11:46:41 Event logging started
      2017-12-29 11:46:50 HTTP client 10.0.0.6 login succeeded
      2017-12-29 11:46:51 HTTP client 10.0.0.6 disconnected
      2017-12-29 11:47:30 WiFi reported error: Listen failed
      2017-12-29 11:47:40 WiFi reported error: Listen failed
      2017-12-29 11:47:51 HTTP client 10.0.0.6 login succeeded
      I'm using this command, which worked with an earlier v1.20 beta and the 1.19 WifiServer,
      I never upgraded the WifiServer on my previous FTP tests with newer RRF betas:
      [c]curl -vvv ftp://10.0.0.42/sys/bed.g[/c] or [c]wget –debug -r -nH ftp://10.0.0.42/sys/[/c]
      Output of curl when it fails:
      *   Trying 10.0.0.42...
      * TCP_NODELAY set
      * Connected to 10.0.0.42 (10.0.0.42) port 21 (#0)
      < 220 RepRapFirmware FTP server
      > USER anonymous
      < 331 Please specify the password.
      > PASS ftp@example.com
      < 230 Login successful.
      > PWD
      < 257 "/"
      * Entry path is '/'
      > CWD sys
      * ftp_perform ends with SECONDARY: 0
      < 250 Directory successfully changed.
      > EPSV
      * Connect data stream passively
      < 500 Unknown command.
      * Failed EPSV attempt. Disabling EPSV
      > PASV
      < 227 Entering Passive Mode (10,0,0,42,16,132)
      * TCP_NODELAY set
      * Connecting to 10.0.0.42 (10.0.0.42) port 4228
      * connect to 10.0.0.42 port 21 failed: Connection refused
      * Failed to connect to 10.0.0.42 port 21: Connection refused
      * Closing connection 0
      curl: (7) Failed to connect to 10.0.0.42 port 21: Connection refused
      It looks like the first file transfer works (sometimes a second one too), and then all following connections fail.
      A power cycle or "emergency stop" via DWC makes FTP usable again - for a single file, then the bug reappears.
        Thanks for your report. Which FTP client program are you using? How large are the files you are uploading?
        Please can you connect via USB as well, send M111 S1 P14 to enable WiFi debugging, then post the output you get when the error occurs and when you do a subsequent M122.
        • resam
          I'm using wget or curl from a terminal to download config files from the sys folder on the SD card.
          The files in question are small - typically a few hundred bytes, up to max. 4.2kB.
          I'm using FTP to do download & backup all config files to my local computer, since DWC does not have a "Download All" button.
          I'll provide a USB log when I'm back with my machine - I currently only have remote access.
            @resam:
            Yes it does - perhaps you are using an old version. Click on the check box next to "File name" to select all files, then right click on any file and select "Download as ZIP".
            • resam
              You are right, DWC has a "Download as ZIP", however, it is client-side. So if I want to use it from a script (because automated backups etc), I need a bit more scripting. If I can't get FTP to work, I can fallback to HTTP & DWC.
              Here is the debug log you requested:
              e is predicted to reach 554C.
              Done!
              M122
              Used output buffers: 1 of 32 (4 max)
              Board ID: 08DDM-9FAM2-LW4S4-XXXXX-XXXXX-XXXXX
              Dynamic ram used: 99120
              Recycled dynamic ram: 120
              Stack ram used: 3576 current, 4528 maximum
              Never used ram: 11856
              Last reset 00:00:21 ago, cause: reset button or watchdog
              Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11776 bytes (slot 1)
              Error status: 0
              Free file entries: 10
              MCU temperature: min 33.7, current 34.6, max 34.7
              Cache data hit count 61188730
              Slowest main loop (seconds): 0.035510; fastest: 0.000042
              Segments left: 0
              serial is ready with "M122" in state(s) 0
              WiFi flash size 4194304, free heap 13232
              WiFi signal strength -42dBm, reconnections 0, sleep mode modem
              HTTP sessions: 0 of 8
              Socket states:  0 0 0 0 0 0 0 0
              Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
              ok
              M111 S1 P14
              Debugging enabled for modules: WiFi(14)
              Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13)
              ok
               <curl command="" executed="">WiFi reported error: Listen failed
              M122
              Used output buffers: 2 of 32 (10 max)
              Recycled dynamic ram:WiFi: drop:
               120
              Stack ram used: 3576 current, 4688 maximum
              Never used ram: 11696
              Last reset 00:01:46 ago, cause: reset button or watchdog
              Software reset code 0xWiFi: xmit: 0
              Error status: 0
              MCU temperature: min 33.7, current 33.9WiFi: recv: 0
              , max 35.0
              Supply voltage: min 24.1,WiFi: fw: 0
              DriverWiFi: drop: 0
              Driver 4: standstill, SG min/max WiFi: chkerr: 0
              not available
              Date/time: 2018-01-02 12:27:47
              Cache data hit count 392889880
              Slowest main loop (seconds): 0.152726; fastest: 0.000085
              MaxReps: 0, StepErrors: 0, FreeDm: 2WiFi: lenerr: 0
              Heater 1 is on, I-accum = 0WiFi: memerr: 0
              .0
              Segments left: 0
              daemonWiFi: rterr: 0
              queue is idle in state(s) WiFi: proterr: 0
              0
              WiFi MAC WiFi: opterr: 0
              WiFi Vcc 3.35, reset reason Turned on by main processoWiFi: err: 0
              r
              WiFi flash size 4194304, free heap 13160
              WiFi signal strength -44dBm, reconnections 0, sleep mode modem
              HTTP sessions: 2 of 8
              Socket states:  0 0 0 0WiFi: cachehit: 0
               0 0 0 0
              ok
              WiFi:
              WiFi: xmit: 5
              WiFi: recv: 4
              WiFi: fw: 0
              WiFi: drop: 0
              WiFi: chkerr: 0
              WiFi: lenerr: 0
              WiFi: memerr: 0
              WiFi: rterr: 0
              WiFi: proterr: 0
              WiFi: opterr: 0
              WiFi: err: 0
              WiFi: cachehit: 117
              WiFi:
              WiFi: xmit: 217
              WiFi: recv: 169
              WiFi: fw: 0
              WiFi: drop: 4
              WiFi: chkerr: 0
              WiFi: lenerr: 0
              WiFi: memerr: 0
              WiFi: rterr: 0
              WiFi: proterr: 0
              WiFi: opterr: 0
              WiFi: err: 0
              WiFi: cachehit: 0
              WiFi:
              WiFi: xmit: 37
              WiFi: recv: 0
              WiFi: drop: 0
              WiFi: chkerr: 0
              WiFi: lenerr: 0
              WiFi: memerr: 0
              WiFi: proterr: 0
              WiFi: rx_v1: 0
              WiFi: rx_group: 0
              WiFi: rx_general: 0
              WiFi: rx_report: 0
              WiFi: tx_join: 14
              WiFi: tx_leave: 12
              WiFi: tx_report: 11
              WiFi:
              WiFi: xmit: 0
              WiFi: recv: 0</curl>
              I can't see any obvious (additional) error messages, beside of "WiFi reported error: Listen failed" right when I execute [c]curl -vvv ftp://10.0.0.42/sys/bed.g[/c]. It works twice, and the third time it errors.
              I tried to wait with each command to capture the entire log output, but I think there is some multithreading-print weirdness going on (is that even possible?), because some of the lines are interrupted by other output prints…
                Thanks. I will release a new version of DuetWiFiServer soon (maybe later today) which provides additional debug information, so that I can identiy the cause of the "Listen failed" messages.
                • totalitarian
                  totalitarian last edited by
                  You could try to download using curl
                  http://youraddy/rr_download?name=0%3A%2Fsys%2Fbed.g
                  • resam
                    @totalitarian: I'm aware that there are other way to download files.
                    However, this still does not resolve the general issue of FTP killing Wifi.
                    My idea was to use FTP to download ALL files in [c]/sys[/c]. With wget or curl this would be a CLI one-liner.
                    Using HTTP, it would be a few more - nothing complicated, but beside the point I want to achieve.
                    I'm happy to help & debug this until it is resolved - I'm not looking for a quick workaround.
                    Let me know when you have a new DuetWiFiServer FW for me to test.
                    • totalitarian
                      @resam, no worries, just wanted to offer a temp workaround
                      • resam
                        @dc42: Here the latest debug log:
                        M111 S1 P14
                        ok
                        WiFi: fw: 0../src/Listener.cpp(134): tcp_listen failed
                        WiFi: ../src/Listener.cpp(134): tcp_listen failed
                        M122
                        Used output buffers: 3 of 32 (11 max)
                        RepRapFirmware for Duet WiFi version 1.20.1RC2 running on Duet WiFi 1.0
                        Dynamic ram used: 99232
                        Recycled dynamicWiFi:
                         ram: 4104
                        Stack ram used: 3584 current, 4624 maximum
                        Never used ram: 7664
                        Last reset 00:05:37 ago, cause: software
                        Last software reset at 2018-01-02 12:38, reason: User, spinning module GCodes, available RAM 11696 bytes (slot 2)
                        Software reset code 0x0003WiFi: xmit: 0
                         HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0WiFi: recv: 0
                        Error status: 0
                        MCU temperature: min 33.2, current 34.2, maWiFi: fw: 0
                        x 34.4
                        Supply voltage: min 24.1, current 24.1, max 24.4, under voltage events: 0,WiFi: drop: 0
                        Driver 3: WiFi: chkerr: 0
                        Date/time: 2018-01-02 23:26:16
                        WiFi: lenerr: 0
                        Cache data hit count 1283387609
                        Slowest main loop (seconds): 0.154294; fastest: 0.000100
                        MaxReps: 0, StepErrors: 0, LaErrors: 0,WiFi: memerr: 0
                        Bed probe heights: WiFi: rterr: 0
                        Heater 1 is on, IWiFi: proterr: 0
                        -accum = 0.0
                        Segments left: 0
                        file is idle iWiFi: opterr: 0
                        n state(s) 0
                        aux is idle in state(sWiFi: err: 0
                        ) 0
                        Failed messages: pending 0, notreWiFi: cachehit: 0
                        ady 0, noresp 0
                        WiFi firmware version 1.20WiFi:
                        +1
                        WiFi flash size 4194304, free heap 14464
                        Socket sWiFi: xmit: 6
                        tatWiFi: recv: 5
                        es:  0 0 0 0 0 0 0 0
                        ok
                        WiFi: fw: 0
                        WiFi: drop: 0
                        WiFi: chkerr: 0
                        WiFi: lenerr: 0
                        WiFi: memerr: 0
                        WiFi: rterr: 0
                        WiFi: proterr: 0
                        WiFi: opterr: 0
                        WiFi: err: 0
                        WiFi: cachehit: 167
                        WiFi:
                        WiFi: xmit: 262
                        WiFi: recv: 230
                        WiFi: fw: 0
                        WiFi: drop: 0
                        WiFi: chkerr: 0
                        WiFi: lenerr: 0
                        WiFi: memerr: 0
                        WiFi: rterr: 0
                        WiFi: proterr: 0
                        WiFi: opterr: 0
                        WiFi: err: 0
                        WiFi: cachehit: 0
                        WiFi:
                        WiFi: xmit: 34
                        WiFi: recv: 0
                        WiFi: drop: 0
                        WiFi: chkerr: 0
                        WiFi: lenerr: 0
                        WiFi: memerr: 0
                        WiFi: proterr: 0
                        WiFi: rx_v1: 0
                        WiFi: rx_group: 0
                        WiFi: rx_general: 0
                        WiFi: rx_report: 0
                        WiFi: tx_join: 14
                        WiFi: tx_leave: 12
                        WiFi: tx_report: 8
                        WiFi:
                        WiFi: xmit: 0
                        WiFi: recv: 0
                        The important part seems to be: [c]WiFi: ../src/Listener.cpp(134): tcp_listen failed[/c].
                        I noticed that the initial FTP commands work, and once it tries to switch over to passive mode, it fails.
                          Thanks, that's the extra detail that I wanted. Now I just need to work out why that is happening. Are you able to send me a Wireshark trace of the network traffic around that point?
                          EDIT: never mind, I have reproduced the problem.
                            I have fixed this issue. The fix will be in firmware RRF 1.21RC1 and DWS 1.21RC1, both of which which I hope to release soon.
